Thread: Controller Wont Turn On
    Aug 2015
    grande prairie
    2
    So i'm getting ready to refire my old tub for the fall, had it drained all summer. I knew last year i was having a problem with the pressure switch so i replaced that. So filled up the tub and flipped my breakers and nothing. No clicking, no pumping, nothing in the top display. I checked for power and was getting 240 and checked the fuse and was getting continuity. Worked great all last winter.Its a old artic spa with a Balboa Circuit Board, Duplex Digital, 54003. Any tips to get it working again are appreciated
    Jun 2015
    Wildomar, California
    423
    Re: Controller Wont Turn On
    Did you check the line voltage at the main circuit board?
    Aug 2015
    grande prairie
    2
    I get 120 going from ground to white, black, or red. Then 240 going between the wires together. This is at the spa. Everything worked great beside the sticky switch in the spring
