Thread: replacing pump system krystalclear pump died
    Aug 2015
    volcano/ca
    1
    my pump for saltwater system quit working model cs15110 14 inch sand filter I'm on the fence about sticking with the saltwater system but positive I want to change pump to another brand can I modify to another make pump and still use same sand filter I have a 9x18x52" intex any help would be appreciated pumps dead and pools turning green
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: replacing pump system krystalclear pump died
    Not sure about using a different pump with that set up. But, add bleach to maintain your chlorine and brush the pool to mix it to keep it from turning green.
