Results 1 to 7 of 7
Thread: Polyquat 60
    jbriggs1219's Avatar
    Apr 2015
    Brunswick/Ohio
    77
    Polyquat 60
    Can anyone tell me how long I can expect a bottle of polyquat 60 to last before it loses its effectiveness...basically I bought a bottle just for winter closing....if I kept the unused portion in a cool dry place would I be able to use it again the following year?...thanks!
    13,500 gallon AG
    Cartridge Filter
    Raypak Natural Gas Heater
    Jan 2012
    'burbs of Augusta, Georgia
    7,239
    Re: Polyquat 60
    Hang on...good question... ::Paging Chem Geek! Paging Chem Geek!::: Lets see if our resident chemistry expert will chime in
    Aug 2014
    Northern IL
    4,615
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Polyquat 60
    Yes, there are several threads including the one above as well as PolyQuat 60 shelf life and Algaecide Expiration?, but they all point to my original post on The PoolForum where I wrote to Buckman Labs, makers of Polyquat, and they responded:
    PolyQuat is a biocide that is registered with the USEPA; and, as such, it will have a specific guaranteed shelf life. The shelf life (which may or may not be printed on the label) is one year. In general, registered biocides are assumed to have a one-year shelf life unless the label states otherwise. While the compound itself is very stable and is not expected to decompose upon storage, we cannot guarantee it beyond the stated one-year shelf life (due to legal and regulatory considerations).
    In other words, it is "guaranteed" to last one year, but it's a stable compound so would presumably last longer. How long -- well, who knows. And be sure to check the label to see if it states otherwise (i.e. a shorter shelf-life).
    Apr 2015
    Brunswick/Ohio
    77
    Re: Polyquat 60
    Thanks everyone...really appreciate the info!
    13,500 gallon AG
    Cartridge Filter
    jv92red's Avatar
    Mar 2013
    SoCal
    117
    Re: Polyquat 60
    "While the compound itself is very stable and is not expected to decompose upon storage, we cannot guarantee it beyond the stated one-year shelf life (due to legal and regulatory considerations)."
    So sounds like it basically will be fine but possibly less potent as time goes by than what the label says for its stated potency. So just use a little more than the suggested amount.
    I worked at a Pharmaceutical manufacturer a few years ago and learned from the chemists there that "exp" dates on drugs/supplements are not when they 'expire' or go 'bad' like milk. The samples of the drugs/supplements put on stability (shelved) merely do not test out after a specified amount of time to show that the active ingredients match the labeling claim of potency. FDA takes truth in labeling very serious so a manufacturer must prove label stated potency from testing stability samples. So I do not throw out pills at my house. Yes, I use up all of my Advil even though it expired a year or two ago. I just take three pills instead of two...
    15'x35' IG 16,500 gallons w/attached raised 18" spa continuous coping w/underneath spill and ledger stone wrapped, NPT mini pebble aqua blue w/2x pigment & abalone shell finish, 2"x24" travertine coping, 3x Jandy Color LED lights (2 in pool), Jandy Flo Pro 2HP VS pump, Jandy LXI (low NOx) 400K BTU heater, Jandy CL460 cartridge filter, Jandy AquaPure Ei SWG, Jandy Z4 automation with iAqualink and remote poolside PDA, 1,300 sqft Belgard Catalina paver deck with drainage, fire pit that matches the spa with travertine coping and wrapped in ledger stone, Elitewood insulated patio cover, Vinyl gates, back vinyl fence coming soon...
    TF-100
    Jun 2015
    Jackson, NJ
    123
    Re: Polyquat 60
    Is it affected negatively by heat? I've had mine in my storage shed, but it gets pretty hot in there. The bottle mentioned nothing of heat, just dry.
    42' natural free-form pool, vinyl lined, 6' deep end, 21,400 gallons
    2 HP Hayward Superpump, Hayward Aquarite SWG, AquaComfort 125k btu heat pump, 350lb Hayward Pro Series sand filter
    2 skimmers, 2 floor drains, 10 returns (6 in the pool, 2 in the steps, 2 in the swim-out)
    TF-100 Test Kit
