Thread: My intro
    Aug 2015
    TX
    26
    My intro
    Hi All,
    I totally should have done my intro first then gone to my New Construction post but alas, I did it backwards.
    The hubs and I, along with 2 kiddos and a lab, all have wanted our own pool for ages. We finally built our home then saved up for the pool.. aka my Princess Palace. While the process hasn't been easy or smooth we are so thankful to have a pool and love it.
    Inground Pool Size 32x21 - Depth 3-6" x 6'4" - Surface area 440 Sq Ft - Perimeter 93 ft.
    Supposed to have: Hayward Equipment, Hayward Aqua Plus control panal, Hayward 40" sand filter, Hayward 2 HP Tristar pump, 320 commerical grade in line cholinator back up, Hayward Goldline t-15 40kgal salt cell. TF-100 Test Kit w/Speedstir ORDERED
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Re: My intro
    Welcome Grrarrow! Or should I say "your highness" Glad you found us!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: My intro
    Welcome to TFP!
    It's a bummer when your build is a bit of a sour note but going with TFP methods will have your pool singing on pitch for sure.
    Isolated Spa - 345 Gallons
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: My intro
    Welcome to TFP!
