Results 1 to 15 of 15
Thread: New pool owner, which test kit?
    Aug 2015
    Potomac, MD
    93
    Hi,
    I bought this pool test kit before discovering this forum:
    5 Way Swimming Pool Spa Pool Above Water Chemical Test Kit | eBay
    Is it good enough, or do I need to buy something else? If something else, which one?
    Is this #1 seller on Amazon good?
    Amazon.com : Poolmaster 22260 5-Way Test Kit with Case - Basic Collection : Swimming Pool Liquid Test Kits : Patio, Lawn Garden
    Outdoor concrete pool, unsure of size, but about 5' deep at deep end.
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: New pool owner, which test kit?
    You need to add this- TFTestkits.net
    And also this - TFTestkits.net
    Is the kit you bought a Taylor's kit such as K-2005?? We only recommend the Taylor's K-2006 or the TF-100 kit from TFTestkits.net
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    see my signature for a comparison link of the recommended test kits. the TF-100 is the best value for what you get. the recommended test kits will provide you with the tests you need. in order to maintain your pool, you need to know its CYA (stabilizer) levels and FC (free chlorine). the test kit you linked does not provide these, the recommended ones do
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Donldson's Avatar
    NW Ohio
    2,906
    You need a test that is capable of measuring Free Chlorine, Combined Chlorine, pH, Total Alkalinity, Calcium Hardness, and Cyanuric Acid. Despite the advertisement your kit is really only a 3-way test, it tests Total Chlorine, pH, and Total Alkalinity. Your pool doesn't have bromine and the acid demand test is not vital. Also the chlorine test is only useful for getting a vague idea of chlorine levels. The other kit you posted is virtually identical.
    Only two kits accurately measure the levels I mentioned. The Taylor K-2006 and TF-100. Both are similar but the TF-100 has been optimized to contain more of the most used reagents and was designed specifically for the care we recommend on this forum. The K-2006 is available from several locations including Amazon, while the TF-100 is available from TFtestkits.net. Either one is far more useful than the kit you have now.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Aug 2015
    Potomac, MD
    93
    Quote Originally Posted by DaninFLA View Post
    Thanks, I found two places that sell the TF-100, both for $68. Anywhere to get it cheaper?
    TFTestkits.net
    Water Testing - TFTestkit TF-100 Seven Test Kit - TF-100
    Outdoor concrete pool, 14,000 gallons, Purex Triton Clean & Clear Plus cartridge filter.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,108
    Not really, but there is a little secret. If you order from Tftestkits and the order is large enough, like include a magnetic stirrer, I've heard shipping is being comped.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Donldson's Avatar
    NW Ohio
    2,906
    On the East Coast you want to get it from TF Test Kits, located in South Carolina. Pool Supply is on the West Coast. Those are the only two distributors of the TF-100 kit.
    Become a paid member here and get $10 off the test kit. I just did today and ordered a tf100 and stirrer with free shipping.
    Built Aug 2015- 20x40 26000 Gallon free form gunite, White plaster w/ 50% blue quartz, 2hp Jandy Stealth, Polaris 280, 2 skimmers,2 floor drains, 5 returns, bubbler, Grotto waterfall. 2 24" sheer decents, Jandy 48 DE filter, Jandy Aquapure PLC1400 SWG, 2 Color changing led
    Jun 2015
    Raleigh
    357
    Quote Originally Posted by Donldson View Post
    Hush your mouth....TF Test Kits is in Creedmoor NORTH Carolina. About 40 minutes north of me
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Donldson's Avatar
    NW Ohio
    2,906
    Quote Originally Posted by robertmee View Post
    North Carolina, South Carolina, is there a difference?
    From my HTC One via Tapatalk
    Jun 2015
    Raleigh
    357
    About the Same as Ohio and West Virginia...you tell me
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Donldson's Avatar
    NW Ohio
    2,906
    Yes, Ohio is West of West Virginia. And where I live we are more like Indiana than WV anyway.
    Ok, I will stop this bus before it gets more off target. My mistake, ever since Dave changed his location to Florida I forgot where TFT is located.
    Aug 2015
    Potomac, MD
    93
    Quote Originally Posted by pabeader View Post
    I tried ordering from tftestkits and included the magnetic stirrer and XL option and am still being charged $10.95 shipping.
    At poolsupplyworld, the test kit is $68 with free shipping so I ordered it from there. Also got the magnetic stirrer for $33.35 shipped from Amazon (Amato Industries):
    http://www.amazon.com/gp/offer-listing/B004BGPC5W/
    30,426
    Grayson73,
    As TFTestkits, I cannot conduct customer service on the forum. Please CALL them @ 919.528.1454.
    PoolSupplyworld is a fine resource. Your kit will come from California and take about 5-6 working days to get to you.
    30,426
    To help clarify, Rebecca, my daughter, now owns TFTestkits.........still shipping from Creedmoor NC. She is available by email @ TFTestkits@gmail.com
    I have moved to Sebring, Florida (man, is it humid ) and will remain as active as ever on the forum and consult and assist Rebecca. This took place in January of this year and I probably should've let everyone know. I am sorry for the confusion.
