Thread: sand filter works in every position except filter
    Aug 2015
    Seguin
    1
    I just inherited a used sand filter and pump and installed on my above ground pool and the multiport valve works in every position except the filter position. I watched several diy videos on how to install but must have gone wrong somewhere. Any ideas?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: sand filter works in every position except filter
    Do you have a brand and model number you can share? An image of the installed filter would help a lot as well. Posting Photo's Tutorial
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Please provide a better description of what you mean by not working in the filter position. Need more detail than that. How doesn't it work? What are the symptoms that lead you to believe it doesn't work?
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Oct 2007
    Cedar Hill, TN
    252
    Is the spider gasket in the proper position??
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
