Results 1 to 8 of 8
Thread: And now, a Few Words on Food Safety & Proper Handling
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Although summer is winding down for many of us, there are still ample opportunities for outdoor cooking and eating events as we head into fall. Many of us will have one last pool party of the season on Labor Day weekend. After that, football season will begin and, for many of us, that means tailgating. In order to ensure that a good time is had by all, I thought it would be a good time to discuss food safety. It’s also very timely since I recently had a bout with food poisoning. If this write-up prevents at least one person from getting food poisoning, it will have been time well-spent in putting it together.
    Here’s the scenario that I just recovered from…A friend of mine picked up some BBQ (brisket). After having dinner, we divided up what was left for future meals. About 4-5 hours after dinner, I felt a bit queasy but it quickly passed and I didn't give it a second thought – I chalked it up to having an off-day. Two days later, I had more of the remaining brisket. Turned out not to be a good thing. Like the first night, I began to not feel good about 5 hours later. I didn't get off so easy the second time around. The next 24 hours or so were dismal. Was literally up all night and felt miserable the next day. I then called my friend and he experienced the same thing. Much as I hated to, I tossed the remaining brisket. Although I didn't know it at the time, I later found out that my friend (not one of my tailgating buddies who would have known better) picked up the brisket and then did several errands before we met up. All the while, the brisket had sat in the car for a few hours between when he picked it up and when we dug into it, even though it still seemed warm. As the brisket sat in my friend’s car for around 3 hours at temperatures averaging between 90 and 100F, the brisket cooled off just enough, and for a long-enough period of time, to become a target for bacteria to set up shop and proliferate.
    Traditional BBQ, especially brisket, pulled pork, and ribs are among the safer items at a cookout since they are cooked/smoked to high internal temperature (around 200F) and then held there for several hours to make them tender. This temperature is much above the temperature where bacteria are instantly killed off and food is considered safe per FDA guidelines (e.g., 165F). So you may be curious as to how meat cooked to such a high internal temperature for so long could become contaminated. Well, we need to delve into a little microbiology to find the answer – I’ll keep it simple, I promise!
    When we think of bacteria, we are usually referring to the “vegetative” state. This is the living state where the cells divide and multiply rapidly. In the case of bad bacteria, this rapid multiplication and the toxins they produce is what causes illnesses like food poisoning. Some bacteria can morph into a second state called an endospore (a.k.a., spore). This happens when the environment becomes hostile for the bacterium to proliferate in the vegetative state. The spore is a dormant state that allows the bacterium to survive more hostile conditions (such as some cooking environments) in a “stripped-down” form compared to the vegetative state. Spores can be found in food, air, water, and soil. While in spore form, bacterium do not divide and multiply like they do in the vegetative state. When the environment becomes more favorable to the bacterium, the spore can regenerate back into the vegetative state and multiply. The good news for us is that the process of going from the vegetative state to spore and vice-versa takes some time – several hours depending on the type of bacteria and the environment. This can be used to our advantage during the cooking process and it gives us some lead time to pack up and store leftovers down below 40F before any spores can regenerate.
    The above process illustrates how even properly cooked meats can become contaminated through improper handling and holding. If food is left out for a sufficiently long time before serving, or if it is left on the table for people to nibble on later, the meat can cool into the heart of the “Bacterial Danger Zone” of 40-140F or 4-60C. If it is allowed to stay within that temperature range for a long-enough period of time, it will permit any spores that may have survived the cooking process to regenerate into the vegetative state and contaminate the food.
    A few general tips on avoiding food poisoning:
    1. Don’t thaw meat on the counter at room temperature– ever! In fact, when I cook burgers, I place them frozen on a preheated grill. I don't notice much difference in the cooking time and I think they come out better vs. thawed.
    2. Cook foods to the proper temperature. For grilled chicken and ground beef, this means an internal temperature of 165F / 74C. Use a good digital thermometer to confirm.
    3. If you are doing traditional smoked BBQ, you will cook the meat to an internal temperature well in excess of 165F, so no worries about under-cooking. However, I would strongly suggest maintaining the temperature of your smoker to at least 225F while the meat is cooking. Depending on what I’m BBQ’ing, I have been known to start the BBQ cook with the smoker at 300-350F and let it gradually come down to 225-250F or so for the duration of the cook. This gives the raw meat an initial blast of heat to minimize the time that the interior of the meat is below 140F. It will also kill off more bacteria while in the easier-to-kill vegetative state before they have time to morph into spores and it increases the likelihood that any spores present on the surface of the meat prior to cooking will be killed at this higher temperature. It also sets the stage for a firmer bark on the meat which I prefer.
    4. While serving, keep hot food above 140F / 60C and cold food below 40F / 4C. This is not limited to meat products. An often-overlooked source of food poisoning are sauces (e.g., BBQ sauce and bastes) especially those containing meat drippings . Here’s a typical scenario: You decide to use some marinade or BBQ sauce as a baste or finish dressing. Even if the sauce/baste was first brought to a boil or to “bubbling”, some spores that were present within might survive. If it is allowed to cool to ambient air temperature, any surviving spores could “hatch” in the cup of basting sauce you’ve had sitting next to the grill for a few hours and that you just applied to the meat.
    5. Cool down, as quickly as possible, leftover hot foods after eating: The FDA requires food processors to get the temperature of hot food down to 41F in six hours. This assumes the food has been sitting at room temperature (~70F). In an outdoor event where the temperature is often at or above 80F, you have less time since biological processes happen much faster at these temperatures. If you do not have a reliable way to keep hot foods above 140F during the entire serving time, I would make a “last-call” after about one hour of the food being removed from the cooking source. Recall that even if spores are present, it will take several hours to regenerate into vegetative bacteria if the food temperature gets into the Danger Zone of 40-140F, so you do have some lead time. After “last call”, take any leftovers and put them in large zipper-type freezer bags. Then place them in ice, preferably in a separate cooler from beverages. This will quickly cool the food down below 40F. When you get home, place these items in the fridge or freezer.
    I know this question will come up: How is it that I can eat a steak (filet, NY strip, porterhouse, etc.) rare or medium-rare that is cooked to an internal temperature of 125-135F and have it be safe? Well, there’s always a slight risk with anything. However, microbes do not penetrate whole muscle meats very well, so the interior of a fresh steak is pretty safe. Since these type of steaks are usually cooked directly over the heat source and at a much higher temperature compared to slow-roasted BBQ, all vegetative bacteria and virtually all spores on the surface are killed almost instantly by the heat of cooking. Just note that even with these steaks, they can become contaminated if left out too long after cooking unless they are kept at 140F or higher. Just avoid any steaks that have been “blade-tenderized” which involves stabbing the meat with a sharp instrument such as a fork or jaccard. This process is sometimes used on tougher cuts of meat. The intent is to pierce the tough connective tissue to make the meat more tender. This will also push any surface bacteria towards the center of the meat and increase the risk of contamination.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    Re: And now, a Few Words on Food Safety & Proper Handling
    Thanks for that handy info! I love bbq and smoked foods and this will help improve my serving techniques and handling. Sorry you had to take one for the research team!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Good info. Be safe with that food!
    Isolated Spa - 345 Gallons
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,651
    He can cook at my house any time!
    Very good info! I had food poisoning about 2 months ago from a Co-workers retirement party where we had the food brought in by a well known BBQ franchise. And I think what you described is exactly what happened. I would never wish the pain I went through on anybody. I was always careful with my food, but after that episode I am really extra-extra careful with food now. I never want to go through that again.
    17.5K IG Pool with Spa spillover and fountain, Plaster Finish, Purex Triton CC420 Cartridge Filter, Pentair Intelliflo XF VS motor, Laars LX GasHeater, Polaris 360
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    A couple of other things I should have mentioned that most people wouldn't think of as a potential source of food poisoning:
    1. Foil-wrapped baked potatoes - specifically holding them in foil to keep warm after they have been baked. This has been linked to botulism (!) I recently learned about this potential risk myself, did some research, and found it to be true. Once again, this has to do with bacterial spores. Remember that spores are present in the air, soil, water, and some food products. Since potatoes are tubers that grow in the ground, they could be exposed to these spores. Apparently, the foil can seal the warm potato from oxygen - an important point since Clostridium botulinum is anaerobic, meaning it grows when no oxygen is present. If the foil-wrapped potato is allowed to cool below 140F / 60C, it can set the stage for any spores present to regenerate into the vegetative state, multiply, and produce their toxin. So again, the risk is not while they are wrapped in foil while cooking in the oven or on the grill, but removing them from the cooking source and leaving them wrapped in foil as they cool. I've started preparing baked potatoes by zapping them in the microwave to give them a head start and minimize the time they are between the temperatures of 40-140F. Then I finish them in the oven or on the grill and keep them there until serving time. Here are a couple of resources: http://www.bccdc.ca/NR/rdonlyres/B21...e_Botulism.pdf and Botulism | FoodSafety.gov
    2. Small commercially-prepared individual serving condiment packets such as ketchup, mayonnaise, mustard, etc. that look firm and puffy. These packets should normally be relatively flat and pliable. If they look firm & puffy like a small balloon, discard it. Odds are that the puffiness is caused by gases given off by bacteria.
    I should note that this post is intended to be informative, not cause alarm or make anyone hesitant to partake in a potluck, tailgate, or outings where food prepared by others is served. Using myself as an example, I have been to many more tailgates than the average person, have hosted and attended countless big parties with a wide-array of food (hot and cold), and often partake in company outings where catered food is brought in. In over 50 years, my recent bout with food poisoning was only the second that I could recall - the other outbreak was over 30 years ago. It's possible that I could have had something as a child, but don't remember it. So, I still plan on having brisket, baked potatoes, and all the other foods I enjoy. But I am armed with the knowledge to steer clear of any food that I know has been left out too long without being properly warmed or cooled - that's where the biggest risk is.
    Jun 2014
    Rogers, AR
    428
    Great post! I did not know that about potatoes thank you.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    Sep 2009
    Frederick County, MD
    185
    To distill it into pool terms.....
    If the BBQ had some sort of buffer against getting to a bad temperature (CYA), the bacteria (CC) would not have been an issue. )
    Good points all around, and as an avid tailgater this is good advice.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
