Thread: Stenner Tank Dimensions
    Jul 2015
    Woodbridge, VA
    18
    I am interested in getting a Stenner 15 gallon tank but have limited space. I only have about 16" of space [front to back] where I would like to put the unit. According to the Stenner specs it states the unit as being "20.5 OD x 25.3 in.". Anyone know if this will fit in a space with a max of 16" front to back? Thanks in advanced.
    V/r,
    Bryan
    15K Gunite; Pentair FNS Plus 48 - DE, Pentair Superflo VS, Raypak 2100 heater, Stenner 45MHP10 /w 15 gallon tank, TF-100
    22,553
    Re: Stenner Tank Dimensions
    The stenner tank is short but a bit wide. The 20½" OD is how wide the tank is. However, you can get a standard 15 gallon plastic drum and it should fit fine. A standard 15 gallon drum is ~14" diameter and ~26" high.
    Jul 2015
    Woodbridge, VA
    18
    Bama Rambler,
    OK, and thanks. I figured that was the case but wanted to make sure.
    V/r,
    Bryan
