Thread: Solar cover, rain & leaves
    Aug 2015
    Grandy, NC
    135
    Finally enjoying pool after stabilizer problems. All good now. Have decided to put solar cover on to continue using pool while temps start to cool. Few leaves and blown in debris from quick storm last nite on cover. Expectations if we just dump cover into pool while removing to use, besides vacuuming dirt and leaves? Will leaf/water "soup" start anything? Check FC every nite and add what's been lost during day and run pump 24/7.
    Thanks.
    19300 gal, AG vinyl, 1 HP Pentair Dynamo two stage pump, 5 yr old Hayward Vari-Flo sand filter, pool 14 yrs old, well water, testing with Taylor K2006
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Solar cover, rain & leaves
    It is always best to keep as much foreign material out of one's pool but sometimes it just can't be helped. I think I'd try removing the cover as careful as possible to minimize dumping of accumulated debris but don't freak if you completely fail at this. Perhaps run the filter a bit longer and test the water a tad more just in case. Leaves from trees tend to be acidic as they soak in water so if anything, perhaps your pH might go down a tad but most folks fight pH rising so it may not be a big deal.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    domct203's Avatar
    Jun 2015
    CT
    3,592
    I cover my pool every night (pool sees a lot of shade during the day), when I open in the morning I skim out anything big, otherwise I don't fret over it.
    As long as you maintain a proper FC/CYA ratio you will be fine. I use the recommended FC target as my minimum FC, and target 1-2ppm above that because of all the debris from the trees overhead (my 5yo calls it "tree-bris").
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Aug 2015
    Grandy, NC
    135
    Thanks - thought this was way to go, but wanted to check with the experts since I am still learning.
    Karen
