Thread: Antifreeze
    Aug 2008
    Southwest New Hampshire
    52
    Antifreeze
    Is it okay to circulate the antifreeze through the pump and filter and back into the pool? Last fall I blew out the lines and I think I put in roughly 8 gallons (2 gallons in each line). If it is advisable to get as much antifreeze out as possible, how would one go about accomplishing that? I'm thinking to create a bit more suction...close down the line valve at the pump and use the shop-vac pool side...might get a little, anyway.
    Andrew
    25,000 gal IG Vinyl - PoolPilot SC48 SWG - Sta-Rite 1HP/System3 CF - AquaCal HeatPump - TF-100
    Re: Antifreeze
    If you used the right kind of antifreeze, RV or swimming pool anti-freeze and not automotive anti-freeze, then it is fine if it gets into the pool. Some people like to startup the pump with the main valve set to vacuum to waste or to backwash, to get as much of the anti-freeze out of the lines and sent to waste as possible, but that isn't really necessary.
    Aug 2008
    52
    Re: Antifreeze
    Thanks, Jason! I did use RV antifreeze. I think I remember reading that it could be used in potable water lines, so I figured it couldn't be THAT bad. Thank you for the reassurance! No Backwash or waste options as we have a cartridge filter, so I'll just pump it through. Just a few days ago the last bit of snow retreated from the pool cover. Fifty degrees out and the kids are asking to swim!
    Andrew
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Re: Antifreeze
    The difference between ethyleneand propyleneglycol will make a big difference, eh?
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
