Just got my TF-100 test kit! Very exciting even though my pool is still about 2 weeks from being finished.
I have a question. In the instructions it recommends:
"Removing the Taylor K-1000 and keeping it near your pool (but not outside) for frequent testing of pH and Chlorine. The rest of the kit will last longest if you keep it in a controlled environment, away from heat, humidity and direct sunlight."
I was originally planning on storing the entire TF-100 in my vertical outside storage shed with my pool chemicals. It should be inside this shed, in shade the majority of the time, but yes the temps will be up there. Should I keep the whole kit inside the house? Thanks.
