Results 1 to 8 of 8
Thread: Bleach?
    Aug 2015
    Wheatfield, NY
    57
    Bleach?
    I read in some threads that pool store shock is not recommend by the people on this forum. The shock at my pool store is 12.5% Sodium Hypochlorite. Another pool store sells 10.0% Sod. Hyp. The chemical company down the street sells "fresh pool chlorine" and its 12.5% Sod. Hyp. The grocery store sells bleach that is 8.5% Sod. Hyp. Other than price and concentration, what's the difference?
    The chemical company has the best price. I didn't calculate the grocery store price on a =% basis, but they don't have enough on the shelf to make it worthwhile.
    Donldson's Avatar
    NW Ohio
    2,892
    Re: Bleach?
    There is no difference aside of price and concentration, buy whichever is best for your situation based on price and convenience.
    I don't know of anybody that doesn't like the higher concentrations, the issue is that typically "shock" refers to powdered chlorine, which contains calcium or CYA (or rarely lithium) to bind the chlorine to a powdered form. This adds unwanted extras, which is why we prefer liquid chlorine. So yes, feel free to buy sodium hypochlorite from any source you prefer.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Bleach?
    Granular shock is not recommended because it add CYA to the pool. Any liquid chlorine 10%, shock 12% or bleach 6-8% is fine.
    Jun 2014
    15,093
    Re: Bleach?
    I'll use whichever is cheapest and available (Pool store liquid shock @ 10%, Wal-Mart "Great Value @ 8.25%, etc). I'm easy when it comes to bleach.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Bleach?
    Quote Originally Posted by Texas Splash View Post
    +1
    This may help you figure out what is the best way to go.
    It will Calc the cost per Oz of Chiorine
    Chlorine Price Per Ounce Calculator
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Bleach?
    Sometimes I buy the more concentrated, just because I don't have to add as much. 6 of one, half dozen of another.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Bleach?
    Price divided by number of ounces divided by percentage as a decimal (12.5% = 0.125) gives you the cost per ounce of hypochlorite. The lower number is the best deal. Given two equal costs/hypochlorite go with the more concentrated for convenience, provided you're going to use it soon.
    Isolated Spa - 345 Gallons
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Bleach?
    Link posted already
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
