Thread: Polaris Outlet Right Angle connector
    When my polaris pump was installed many years ago, the installer used a right angle connector from the top of the discharge because it gave a better angle to avoid a big loop. Long story short, I need a new right angle connector, but my googling skills have failed. It doesn't appear to be a polaris part, is this a generic part?
    --Tom
    Plaster pool 22,000 Gallons, Hayward Swimclear C5030 Filter, Hayward SP3200VSP TriStar VS Pump, Pentair Minimax NT Heater
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Polaris Outlet Right Angle connector
    It is probably just a threaded 3/4" PVC fitting, right? Threaded on one side and perhaps slip on the other? All 3/4". A picture would confirm.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Yes, you are correct. I went to the hardware store to confirm. Thanks. I just have never used 3/4" threaded PVC, so It didn't occur to me it would be quite that common.
    Thanks.
