Thread: Pentair dynamo motor bearings
    May 2015
    RedBud,IL
    42
    Hi all.
    I have a pentair Dynamo 1 hp pump, and the motor is sqalling. Mainly after it's been off for a while and I re-start it and it go's away after it runs awhile. I was wondering if anyone knew if the bearings could be replaced in the motor. I checked to see how much a new motor costs and I might as well by a whole new pump. But if the bearings are replaceable it would save me a bundle! Thanks.
    21 ft agp, 1 Hp Pentair Dynamo pump, Pentair sand dollar filter with Intex Swg.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Pentair dynamo motor bearings
    Most generally, the bearings can be replaced. You can do this yourself. You may need to open the motor up to find the bearing stock numbers if you can't find that info in other ways.
    While you are searching for the bearings, you should also look for a seal kit for your pump. Cheap insurance to replace the seal and o-rings while you have the pump apart.
    22,551
    The bearings can be replaced and as Charlie said it's a very good idea to go ahead and replace the shaft seal.
    I believe that the bearings are #6203 on both ends. You probably want to check to be sure.
    The shaft seal should be a PS-200.
    Most pool stores should have the bearings and seal in stock. You can also find them at most bearing supply houses.
    May 2015
    RedBud,IL
    42
    Thanks to everyone. I was hoping that was the case. Where I work we replace motor bearings alot. just some electric motors are sealed and was hoping someone knew before I tore it apart for no reason. Also thanks for the tip on the seals. Didn't think of that.
    By the way rambler. Where in alabama are you from. I have kin around the Foley, Gulf Shores area.
    22,551
    I'm north of Mobile. My sister and mother live near Foley. I also have other kin that live in that area.
    May 2015
    RedBud,IL
    42
    Thats a nice area. We usally get down there about once a year or so. just there the last week in july.
