Results 1 to 9 of 9
Thread: To Close? Or Not to Close?
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    I know that some people in warmer climates leave their pools open year-round. What is the criteria for this decision? I feel like we could go either way, being in north AL. What are the pros and cons of doing a full close vs. leaving the pool open and using a mesh cover for leaves, etc.?
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: To Close? Or Not to Close?
    I would think in Alabama you could go without closing entirely but covering to limit chlorine loss and keep the leaves out. You'd only have to make sure that the pump was running when/if the temps dropped below freezing but it would even take quite some time at say... 20 degrees F to risk freezing. Looks like in your area, November through February would be the only times you'd usually be even close to a risk of this situation of being below 30s. You'd still want to likely circulate a couple hours per day and maintain at least some free chlorine levels during this time, perhaps using a Polyquat-60 algaecide to help keep things at bay if FC levels should drop. Any time water temps are below 60 degrees regularly, there's limited risk of developing algae. If you did do a full close by blowing out return lines and and air locking your main drain and skimmer lines then do so only when water temps are firmly below 60 degrees. You'd for sure want to think about a good algaecide with a full close. Perhaps more folks at your latitude/region can chime in with their thoughts.
    Isolated Spa - 345 Gallons
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The concern is mainly one of plumbing freezing, for your area I expect you would be ok most winters, it is that freak once in every 50 year winter that would be the only real worry, this assumes that you can keep the pumps running and the water flowing during prolonged freezes. Of course we had one of those once in every 40-50 year extended freezes winter before last and we had members as far south as Dallas TX and Atlanta GA with freeze damage to their pool plumbing, etc.
    Ike
    ps I know your climate fairly as I lived in Birmingham for 5 years back in the 80's
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I think generally is to close where it isn't reasonable to expect you can keep things running without freezing. The only dance of staying open in the south is a significant amount of time without power. It takes a while of quite low temps for pool plumbing to freeze and burst, so generally it's a reasonable risk for more southern parts of the country.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Closing? What's closing?
    Divin Dave,
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    I won't say we didn't have a few worries this past winter when it got so cold in Georgia, but we kept the pool running overnight on the coldest and record icy of nights and wrapped all the equipment under heavy tarps and moving blankets with a hanging auto light for a bit more warmth. We had no problems.
    I just can't imagine the hassle of winterizing a pool. I feel sorry for folks who have to.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,102
    So YS, are you OTP? As you can see, I'm OTP North. What are your thoughts regarding the need for me to close my pool? I know the previous caretakers did, but they did a very poor job of it. Mo plugs in anything, the SWG cell was still in place, a plain old tarp that didn't even fit the whole thing. You get the picture.
    I do plan to drain down the filter and stuff so I can completely remove the heater that is not working and I plan to ditch. But I'm wondering if I should just leave it down or keep it full through the winter.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jan 2012
    7,338
    Oh honey...we're 2.5 hours from ATL. over near the South Carolina border. So wayyyyy OTP. Being that you're higher up than we are, it does probably get a bit colder where you are.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,102
    color me pink! I saw Augusta and read Atlanta, like everytime until just now!! How funny
