Thread: Can't get the chlorine up
    Aug 2015
    Houston
    2
    Huge storms passed through. Chlorine is 1.5. SWG. CYA is 55. PH good. Salt good now. Added cya and had pumping running 24/7 like bottle said for 2 days. Bleach I put in is gone. Used super chlorinate twice.
    Worried abiut out getting mold. Have test kit TFP 100
    please advise !
    Jan 2012
    'burbs of Augusta, Georgia
    7,239
    Re: Can't get the chlorine up
    Was your CYA 55 before or after you put in (more)CYA? How exactly did you add this CYA? Hopefully in a sock placed in the skimmer or hung over the edge of the pool near a return to agitate it enough to help it dissolve.
    Stop running your SWG at super-blast if you want it to last longer. Use liquid chlorine/household bleach to get your FC level up there. For a CYA level of 60 (you always round up) you need a minimum of 3ppm, 4 being ideal and 24 to SLAM. Mo'better would be if you raised your CYA to 70 and kept the FC at a min of 3, ideal 5, SLAM 28.
    How does your water look?
    Aug 2015
    Houston
    2
    CYA was 40 before adding.
    water is clear but a hair shy of cryatal if that makes ense.
    Siper chlor has has been off and set to SWC is set at 55%
    Pooured bleached saturday, spiked and it disappeared .
    tihe Taylor K1000 for ph and chl shows 3.5! How can that be?? Need to order more product for or TFP test it....
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Sounds like you are right on the edge of an algae bloom and it is consuming your chlorine quickly. Raise your FC to 10 and keep it there for a few days. Test and add several times per day. Might be time to SLAM. It is important not to let your chlorine level drop below the minimum level for your CYA or algae will grow. Chlorine CYA Chart
    Argosy's Avatar
    Aug 2015
    Mississauga, Ontario, Canada
    46
    pooldv is right, you might be on the edge of algae bloom. It started like that a week ago and then I had to SLAM it over the weekend when I realized that it is too late. You should SLAM right away!
    Kyle. I manage a residential complex and taking care of the swimming pool is one of my duties. It is an indoor, 36 000 gallons (140 000 liters), Marbelite, heated pool, with sand filter, and Jacuzzi 1.5 HP pump. Normally I aim to keep the following chemical composure in the pool: FC = 1.5 - 2.5; PH = 7.4 - 7.6; TA = 80 - 90; CH = 200 - 300; Saturation Index = 0.0 - +0.2 Testing Kit: Taylor K-2006
