Results 1 to 8 of 8
Thread: Worry about PH after adding liquid chorine from the pool store
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    I am having problem with my CYA for a while now.
    First, my numbers: (As of 11 AM today)
    FC = 1.6*
    CC = 0.0
    TA = 100
    CH = 250
    PH = 7.6
    CYA = +90*
    My test kit is Taylor R-2006c and the pool is plastered.
    From Orlando, FL
    I saw a table somewhere in the forum with the recommended FC depending on the reading of the CYA.
    Now I hope I did not do something wrong. I added liquid chlorine (from the store). Now my concern is that I added to much.
    The new reading at 6 PM:
    FC = 13.6
    CC = 0.2 or 0.5 depending on the level of the water (10ml/25ml
    TA = 100 (same)
    CH = 250 (same)
    PH = 7.8! maybe a little more.
    CYA = +90*
    I knew that adding liquid chlorine was going raise the PH. My concern is that I don't want to damage anything. I was reading somewhere that it will get back to "normal" eventually.
    Should I add muriatic acid now? Or will it safe to to wait untill tomorrow and take another reading.
    I know I have to drain the pool (close to 2 feet) and refill. Will do it soon but for now I can't .
    Thank you in advance for your help.
    Trevor
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Worry about PH after adding liquid chorine from the pool store
    The chlorine didn't raise the pH so don't try to lower it with acid. What happened is that the high levels of chlorine reacted with the pH reagent which makes it read falsely high. Pictures When the FC drops below 10 you should get a normal pH reading.
    Your FC is a bit high, but far below shock level for 90 CYA so there's no reason you can't swim in it. Pool School - Chlorine / CYA Chart
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Liquid Chlorine / Bleach is nearly pH neautral, so I have to ask why you thought it would raise your pH? Many people think Liquid Chlorine raises pH when they switch to it from trichlor pucks, because their pH level goes up, the truth is that the trichlor is extremely acidic which was likely keeping their pH down before they switched to Liquid Chlorine.
    Donldson's Avatar
    NW Ohio
    2,881
    First, welcome to TFP Trevor! I type slowly so most of what I am saying is repeating, but I will post it anyway
    Second, a pH of 7.8 would not be a problem as it is plenty acceptable. However that brings me to:
    Third, the pH test is not accurate when your FC is above 10, so odds are that your pH is lower than you are reading. Let your FC come down on its own and you will be able to get a more accurate pH reading.
    As you mentioned, an appropriate FC is directly related to your CYA, here is the chart you mentioned: Pool School - Chlorine / CYA Chart At 90 CYA you want to maintain your FC above 7 at all times. Bringing your CYA down will be quite beneficial in the future.
    Also, the K-2006 instructions recommend using 25 ml of water for your FC/CC test, but to conserve reagents you can use 10 ml with a single scoop of powder and each drop is 0.5 ppm. For most situations that is plenty precise enough and will use less than half as much reagents.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mar 2007
    San Rafael, CA USA
    12,082
    Adding chlorine DOES raise the pH, but when the chlorine gets used/consumed the pH drops back down. Specifically, starting with your numbers I calculate that the pH would have risen from 7.6 to 8.2. Also, if you read the pH test fairly quickly, then 13.6 ppm FC isn't going to give you a false reading. Your pH is very likely to be at 8.2 if your initial reading was correct (not sure why you think it's 7.8).
    So if you intend to keep the FC higher and not let it fall, because of your higher CYA level, then yes you should add some acid to lower it. You could wait for your FC to drop to 10 ppm or so before checking the pH again and then adding acid just to play it safe, but I see nothing inconsistent in your numbers.
    Again, hypochlorite sources of chlorine DO raise the pH upon addition. They are only close to pH neutral when the added chlorine is consumed/used. This means that ongoing use of such chlorine doesn't keep having the pH go up and up, at least not quickly (there is a small amount of excess lye in chlorinating liquid and bleach). However, in your situation, you are raising the FC fairly permanently so the rise in pH from your chlorine addition will also be fairly permanent and therefore needs adjustment by adding acid to lower the pH.
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Thank you all for your quick response.
    So, I don't have to worry as long as my numbers of FC is close to 7 or 8. Give or take. This is information is very helpful to me. And thank you for the tip on how to save reagent by using the 10ml instead of 25 and only one scoop of the reagent.
    I will post back with new numbers as I take new readings regarding this issue. I will not test the PH at least untill my FC is below 10 and above 7.
    I am very glad that you all took the time to help me.
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    I came back to say Thank You! to all of you who responded with smart solution to take care of my pool. My pool is crystal clear now. (Let's hope Erika does mess with it) And you guys are correct, never trust your pool store 100%. For instance, I just find out that they were giving me recommendations thinking that my pool was a 12K, when it is actually a 15K. Go figure.
    Have a great weekend all
    Trevor
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by trevorfl View Post
    Trevor
    You have a great test kit, so don't bother even taking water to the pool store for testing. In most of Florida pool stores are a great place to buy liquid chlorine, sometimes a good place to buy muratic acid (Lowes/Home Depot often beat pool store prices) but they provide very little else you need.
    Get comfortable with your test kit, use Pool Math to calculate additions and enjoy your pool.
    Support the site
