You have to make sure your AG pool has polymer top n bottom rail. That is for corrosion, once you know you do, then you can search out a properly sized unit. Unfortunately your AG is a big one, most AG SWG will not produce enough chlorine per day. You should look at one for IG pools. Hayward Aquarite with t15 cell would be my recommendation because they are easy to install, great warranties and with it being oversized you can get 10-12 years out of the cell. Poolsuppliescanada sells that unit at $1,399 I think. The difference between an AG SWG and a IG SWG is the addition of the flow switch for the IG units.
In our short season, with spring clean ups and fall lowering of water. You can easily use pucks and rarely have an issue with cya being to high.
Pucks are the cheapest most efficient way for us northerners. Liquid bleach costs could be over $300 a year, pucks could set you back $150. SWG plus the extra cya they require would cost around $150-$200 every year.
