Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Calling all Canadians!
    Aug 2015
    Lac La Biche, Alberta
    20
    I am interested to know what you are using to Chlorinate your pool. I am having a real hard time determining what the concentration is on the million different kinds of bleach. So far Purox seems to be the best bet for me, but I would like to know what other options are out there.
    15,500 gallons, vinyl, AG. Sand filter, 1 HP Hayward pump, installed June 2015, Taylor K-2006.
    Argosy's Avatar
    Aug 2015
    Mississauga, Ontario, Canada
    46
    Re: Calling all Canadians!
    We use Clorinating Liquid by AQUATECH (AQUATECH LOGISTICS INC., MISSISSAUGA, ON)
    It has:
    Sodium Hypochloride 10.8%
    Available Chlorine Content 10.3%
    That is the best that you can use!
    Kyle. I manage a residential complex and taking care of the swimming pool is one of my duties. It is an indoor, 36 000 gallons (140 000 liters), Marbelite, heated pool, with sand filter, and Jacuzzi 1.5 HP pump. Normally I aim to keep the following chemical composure in the pool: FC = 1.5 - 2.5; PH = 7.4 - 7.6; TA = 80 - 90; CH = 200 - 300; Saturation Index = 0.0 - +0.2 Testing Kit: Taylor K-2006
    Aug 2014
    Northern IL
    4,615
    I am not from Canada, but I keep hearing about something like Canadien Tire??? Something like that.
    May 2015
    Quebec, QC
    37
    Liquid chlorine sold in pool stores or hardware stores with seasonal departments are all the same at 10.8%. 5 Liters is usually 4.99 or 5.99; more rarely 3.99. Remember when maintaining a seasonal pool, it is often cheaper to use cal-h
    ypo at 65% or 70%.
    14 x 28 Jacuzzi vinyl inground pool, Jacuzzi Laser 250 sand filter, Hayward 1 HP pump.
    Mar 2007
    San Rafael, CA USA
    12,082
    Canadian Tire has Aquarius Liquid Chlorine and Purox Liquid Chlorine which are both 5 liters and 10.8% sodium hypochlorite (not trade %).
    Jun 2012
    Bolton Ontario Canada
    45
    The Liquid I buy at my local pool store is 12%, according to them.
    13 and change for 20 L, IIRC.
    16x32 vinyl
    80,000L chlorine
    21" Hayward sand filter
    May 2012
    Toronto, ON
    463
    Quote Originally Posted by Brendon View Post
    Salt water chlorine generator. The only way to go.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    nofa93's Avatar
    Sep 2013
    Montreal, Canada
    46
    Quote Originally Posted by Eauclaire View Post
    ypo at 65% or 70%.
    As stated per Eauclaire. Cheapest to use calcium hypochlorite for seasonal pools. Best deals for Canadians is the HTH 18kg 70% bucket found at Costco.
    20,000 Gallons Vinyl 16x32 Inground with Stamped concrete decking. Hayward Sand Filter. DIY Diaphragm pump injection system. K-2006C Test Kit.
    450 Gallons Standalone Acrylic CALSPA 2006.
    Canadians, Get your test kit here!.
    May 2012
    Toronto, ON
    463
    Why does it make sense to use calcium hypochlorite for seasonal but not all year pools? And I still say SWCG is best!
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by wayner View Post
    In a seasonal pool you would most likely be dumping the water and storing the pool, so the calcium wouldn't build up to a really high level. In a permanent pool the calcium would soon be too high and some water would have to be dumped to keep it in check.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2015
    Quebec, QC
    37
    Wayner, in seasonal pools, there is a bi annual drawdown of pool water; one in the autumn and another in the Spring, which dilutes the calcium hardness acquired through cal hypo additions over the previous swimming season. As pointed out by others here, prolonged use of cal hypo with no seasonal water replacement leads to elevated hardness and the possibility of scaling, so liquid chlorine is preferred. SWCG is perhaps more 'maintenance-free', during routine chlorination, but I don't see too many advantages due to our short swimming season, compared to SWCG running year round.
    May 2012
    Toronto, ON
    463
    Ok,I wasn't aware of the calcium issue. The biggest advantage of SWCG is the vastly reduced regular maintenance. Once you get your salt and CYA levels right in the spring you are good. You may not have to add anything for the balance of the season. No dumping chlorine liquid or solids. Way easier. Nothing else to buy, no chemicals to touch. What's not to like?
    May 2015
    Quebec, QC
    37
    A city of Toronto bylaw forbids discharging salt water pools into the storm drainage system, you have to use your own connection to the sanitary system, is that what you do?
    Also if your pool structure is aluminium, are you not concerned about accelerated corrosion of the support structure?
    May 2012
    Toronto, ON
    463
    I have a vinyl in-ground pool - I don't know what the support structure is made of but I haven't had any issues in the 8-9 years since I had the pool built.
    nofa93's Avatar
    Sep 2013
    Montreal, Canada
    46
    Also Keep in mind that SWCG continuously raises your pH level as it operates.
    canpool's Avatar
    Jul 2013
    Canada
    41
    SWCG here as well in MTL.
    Kafko 15x28 Rectangle granite grey liner pool - Kafko 8 foot granite grey steps / Kafko 8 foot granite grey sunledge - Hayward Equipment - Kafko Safety Cover - Beachcomber 750 hot tub
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    In Ontario, the best source I've found for liquid chlorine is Pioneer Pools. $5.99 for 10 litres of 11%. Sometimes it's on sale for $4.99. As for SWG pools, I've never heard of any restrictions on backwashing into the storms. With all the salt dumped on the roads in the winter it's hard to see how a smidgen more in the summer can be a problem. I'm not a SWG fan because I just prefer fresh water to salty. I also worry about corrosion after seeing the rust on the walls of my neighbour's SWG pool after only 8 years. That said, there's no question that it's the easiest way to chlorinate.
    Lagoon 40x22, Vinyl, 27,000 gal, 1HP WhisperFlo Pump, Pentair 60 gpm Sand filter, Hayward Brominator (used for chlorine pucks only when away), Rheem gas heater, Dolphin M4 Robot
    Waterfall on separate dedicated pump
    Aug 2015
    Montreal, Quebec, Canada
    36
    Swg in montreal as well. I usually use 4-5 bags a year. Costco sells them for 6.99 each. Keeping my CYA at 70-80 works fine for me. Used Cal-Hypo for a one tine SLAM at the beginning of the season since the SWG cant get up to the FC levels needed for the SLAM. Unfortunately, bleach is more expensive vs cal-hypo where I am.
    44000L oval above ground vinyl pool ---Taylor K-2006----
    Jacuzzi Saniclear 20 salt generator, Waterco XLRU50btu Heat Pump
    Jacuzzi L192 19" sand filter, Jacuzzi 1.5hp pump
    Pool School + Test Kits + PoolMath = Happy Times
    If in doubt SLAM - Shock Level And Maintain + Perform the Overnight FC Loss Test (OCLT)
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Hi wayner. Yes, I agree. SWCG is indeed convenient. It's what I use as well. But I would never state that it's "the only way to go". There are frame corrosion issues to be aware of, bylaws for dumping of salt water, stone issues for inground pools, and the up-front cost is very high. It's not a one-size fit's all solution.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
  20. Back To Top    #20
    Aug 2015
    20
    Thanks everyone for your input! I'm just getting informed in order to prepare for opening my pool for the first time after winterizing. I am definitely considering a SWCG - can anyone offer me advice on which kind to purchase?
