Thread: intellichlor ic60
    intellichlor ic60
    Is there a way to connect a intellichlor ic60 to a jandy pda 6. I'm looking to be able to shut off the SWG when the heater is turned on with out have to go to the unit and lowering the percentage. Any help would be appreciated.
    Jun 2011
    Long Beach, CA
    2,790
    Re: intellichlor ic60
    I believe you are out of luck with that. You will need Pentair automation to control the IC60.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,520
    Wood...
    I know squat about the Jandy pda system, but assume it has several relays. If so, you could wire the power supply for the IC60 through one of them. When you select SPA it would energize or degenderize the relay (depending on the type of relay) which would remove the power to the IC60. This of course would only give you an on/off function and not the ability to control the % of output. Turning the system back to pool would turn the IC60 back on.
    If this is not enough info, let me know and I'll see what else I can dig up.
