Results 1 to 15 of 15
Thread: Green film on liner
    Apr 2015
    IL
    37
    Green film on liner
    Hello all..
    A big thanks to this community as you have helped me with many issues.
    First summer with a pool and it's been trouble free (until now).. The pool liner continuously has a green film in parts of the pool (and seems to be getting a bit out of control). I am having to run the Dolphin robot 1-2 times daily and it doesn't seem to keep up. This was not the case in the summer as I went all summer without issues and was running filter about 8 hours a day and the dolphin cleaner maybe once every day or so.
    The fall is coming quickly as we are getting cooler temps here in Illinois early this year. Along with this comes a bit of additional debris in the pool. I can only assume this is causing the liner discoloration?
    I am currently running my filter 8+ hours a day. In fact, it's probably closer to 10+ due to the additional debris. I have the SWG running and the FC levels are usually around 4-5.
    Also note, that I have not had a working pool cover all year--but am scheduled to get it repaired soon.
    I've never used an algaecide.. Is it time for me to do so? Any other advice? Should I be concerned or is this something that will happen every fall?
    FC 5.5
    CC 0
    Ph 7.9
    TA 80
    CYA 80
    I've been having a tough time keeping Ph at or below 7.8 lately.
    Pete
    Vinyl IG, 32,000 gallons, CircuPool 60,000g SWG, Hayward heater, Pentair TA-60/60D Sand Filter , Hayward Super Pump, TF-100 Test Kit
    Jun 2014
    15,255
    Re: Green film on liner
    Hi Pete! Sounds like you need to SLAM via Pool School - SLAM - Shock Level And Maintain. Follow that page carefully and you'll get rid of that green slime. Running the filter longer is no substitute for well-balanced water.
    PS - No algaecides!
    Apr 2015
    IL
    37
    The only time I have ever SLAMed is when opening the pool this spring. That was before I had the SWG. Should I SLAM with the SWG or use bleach?
    Pete
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Better to use bleach and not wear out your SWG prematurely. Plus, then you know what you chlorine consumption is.
    Apr 2015
    IL
    37
    Well, that's why I am surprised you are recommending a SLAM.. My CC's have been at 0 every time I have checked (three times in the last few days)
    Pete
    Jun 2014
    15,255
    That's understandable. You can have algae with no CC's. It just means the "trash" chlorine has not been processed yet or is awaiting oxidation. Once you start your SLAM, you will probably see the CC number rise at first.
    Jun 2015
    Raleigh
    357
    You didn't post your CYA results. Depending on CYA level if you let your FC fall to 4 that could have been the beginning of an algae bloom.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Wow, y'all beat me!!
    Bleach. In fact you can turn the SWG off while you are slamming. The can save some of the useful life of the cell.
    What is your CYA level?
    How is the circulation in that part of the pool?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Quote Originally Posted by pmaroun View Post
    Have you performed an OCLT? That will tell if organics (algae) are taking hold. By your descriptions, you have algae and need to SLAM.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Apr 2015
    IL
    37
    thanks everyone.. Updated my CYA 80.
    started in the deep end and now has spread all over.
    Pete
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Don't even bother with the OCLT then, get to SLAMming!
    With a CYA of 80ppm your SLAM target is 31ppm. Maintain that, or slightly higher to make up for expected losses between testing/adding chlorine.
    Time to buy a lot of bleach.
    Dom
    Dom - TFP Guide
    Jun 2014
    15,255
    Don't forget to turn off or dial-down that SWG as well if you haven't already. Follow the SLAM page carefully and you'll make it. Good luck!
    Jun 2015
    Raleigh
    357
    With a CYA of 80, your FC target is 6 with a minimum of 4 assuming your SWG is in good working order. If you were keeping it at 5 there's a good chance it dropped below 4 often.
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Apr 2015
    IL
    37
    Yep.
    I was running at a CYA of 60 or under much of this year.. I kept trying to get it up to 70 but we had lots of rain (and lots of draining) this year.. A while back I added a bunch of CYA (maybe a bit too much) to get to 80.. And then never adjusted my FC to match. Hence, the problem.
    Pete
    Aug 2014
    Northern IL
    4,615
    I think the algae probably started in areas that your cleaner can't get to very well. You need to still brush those areas, especially now. Happy slamming!
