Results 1 to 10 of 10
Thread: Should I make use of these???
    Jun 2015
    Mesa, AZ
    16
    my pool came with dual suction ports but since installing the hayward skimmer I'm not using these. should i connect them to also work with the suction or maybe connect them for return?
    22' X 52" Intex Ultra Frame AGP 10,400 gallons
    Intex 3,000 GPH sand filter & Hayward thru-wall skimmer
    Taylor K-2006 test kit
    Jun 2014
    14,961
    Re: Should I make use of these???
    My first thought was for more returns to increase circulation. Let's see what the rest of the crowd has to say.
    May 2012
    Las Vegas, NV
    92
    I would use one with a pvc ball valve, this will allow to make it easier when you vacuum. You can open it after you're done vacuuming and shut off the skimmer. This will allow you to remove the equipment without getting out of the pool to turn off the filter pump.
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    Jun 2015
    Mesa, AZ
    16
    If I make them returns for a total of 3 (already replaced the intex one with the Hayward that came with my skimmer) would the skimmer and the 2 returns fight each other so to speak with having skimmer installed in between the 2?
    Jun 2014
    14,961
    It might depend on how you angle them. If you were able to put a 45 degree PVC on the inside for example so you turn or twist each return to customize the direction of flow, it may work-out fine. You can always test circulation by dropping some packing peanuts or ping pong balls in there and see how it goes before you do anything permanent.
    Aug 2015
    LEAGUE CITY
    6
    Perhaps this is posted elsewhere, but I would love to know how you installed the Hayward Skimmer in an Intex pool....do not want to hijack this post though.
    Katiesmom
    AG (20 years and counting) Intex Metal Frame 24' round 15,000 gallons Intex Sand Filter and SWG new July '16. Hayward wall skimmer. Hard plumbed.
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    I enlarged my two intex outlets to 1 1/2 inches and "Teed" one of them below the skimmer to serve as a vacuum port. Each line, the skimmer line and the vacuum line, have ball valves so I can run one or the other, or both as I need. The other I hooked up to my old intex pump to serve a water feature I plan to add.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Jun 2015
    Mesa, AZ
    16
    Quote Originally Posted by Katiesmom2000 View Post
    http://www.troublefreepool.com/threa...-Pool-%28PICS!
    Jun 2015
    Mesa, AZ
    16
    Thx for all the replies on this. I went ahead and purchased the parts to "T" into either suction or return. Still not sure what to do, the pool doesn't get lots debris from trees or anything. If I make them returns will that mess with pump pressure? Running 10psi now.
    Aug 2014
    Orange Park ,FL.
    6
    Well on my pool i had the same problem after adding skimmer, what i did was make them into 2 returns one aimed at the bottom of pool to keep things stirred up on the bottom so they can be removed by the skimmer, and the other which is on an Intex pool is at water level so it keeps the water circulating and i have never had a problem with these returns being that close to the skimmer
    Intex 16' X 48'' AGP 5000 Gallons 3000 gph sand filter
