Thread: Pool Cover
    May 2015
    uniontown, ohio
    62
    Pool Cover
    Are mesh covers good--I was reading that the snow melts into the pool! Doesn't seem good, but I wasn't sure.
    30,000Gal, Vinyl, IG, Pentair Superflow 1.5HP, Pentair FNS P60 DE Filter, Hayward Chlorine Feed CL200, Dolphin Supreme M5, Taylor K-2006C FAS-DPD Test Kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool Cover
    I use a mesh cover and we get plenty of snow here. Nothing wrong with a free refill of the pool in spring. I'd rather do that than mess with a solid cover that will have extreme sag and having to run a pump cover until after the water freezes.
    Isolated Spa - 345 Gallons
