Thread: Best pool cleaner on the market?
    Jun 2015
    Ottawa/Ontario
    336
    Hi all
    Looking for some advice from all you smart TFP members.
    We have a creepy krawley, as well as the pool hose and vacuum system. However, both are a pain to operate, frankly. We don't really want to shell out 750$ or more for the robot cleaners, and have started looking at manual cleaners such as the Pool Blaster Max as something in between the hose and vacuum and the robot.
    Anyone with any thoughts they care to share as to your preferred options for pool vacuuming tools and techniques?
    Thanks!!!
    Tom
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Best pool cleaner on the market?
    I use and really like my "ThePoolCleaner": 2 Wheel automatic swimming pool cleaner -- The PoolCleaner
    Hayward has bought them and now sells it's own version of the cleaner: AquaNaut® 200, 400 | Cleaners | In Ground Pool Cleaners - Hayward Pool Products
    Mark
    Jun 2011
    Long Beach, CA
    2,778
    I don't think a manual type of vacuum is the way to go if you want something less painful to operate than a suction side cleaner. Manual work to me is a lot more hassle than hooking up a suction side cleaner and letting it run for a few hours.
    "ThePoolCleaner" would be my first suggestion for you along with mas985.
    Apr 2015
    So. Cal.
    139
    Just curious what you don't like about the kreepy krawley....we have one as well that came with the pool when we bought the house. First pool so not a whole lot to base it off of... I was hoping that it would clean better for the amount of time it's in use. So just curious what your issues with it are...
    13000 Gal rectangle gunite w/Aqua-Glass IG lap pool built in 1987 resurfaced (Aqua-Glass) in 2010, Hayward Max-Flo VS pump (model SP2302VSP)
    Rheem Gas Heater 266,000 BTUH (P-M267A-EN-C), Hayward Pro Grid D.E. Filter model DE3620, ThePoolCleaner, CoverPro safety pool cover, TF-100 test kit w/SpeedStir
