Results 1 to 12 of 12
Thread: Test kit comparison...
    chopshop's Avatar
    Aug 2015
    Florence, AZ
    34
    Newbie here, so please bare with me. Our pool will be completed in about ten days and after lurking here, I've decided to use the TFP system of maintaining our pool. My question... Why is the TFTeskit recommended over the Taylor 2006C? Is there an advantage over one another?
    I've looked at the test kit comparison page on this site and about the only (major) difference is the TFTestkit has the abaility to test chlorine OTO, and price as well. However, I really like the case that the Taylor comes with. Maybe someone can sweet talk me into one or the other.
    11k gal., IG, Pebble, Hayward 425 Cartridge, Hayward Eco-star Variable speed pump, 3-5-4, Startup 9/1/15, In-floor cleaning system, City Water, Aerator, Full sun, and of course ambition!
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Test kit comparison...
    The difference is that the TF-100 kit provides more reagents for the tests you will actually want and need to do more often. So its got more bang for the buck, so to speak. If you're having problems with algae or need to perform a SLAM procedure, you'll need to be able to do more testing.
    What you want but don't know it yet is the Speed Stir device. I can't begin to tell you how much easier this makes my testing. I'm not terribly coordinated to swirl the sample while squeezing the drops from the reagent bottle...more swirls...did I lose count?...it can be comical looking to see me. You WANT this device, trust me.
    Aug 2014
    Northern IL
    4,615
    I have to admit, I like the box too. If you go that route, you can always get replacement reagents from tftestkits and refill the original bottles.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    It is just the wrong mix of tests. More cya tests and less TA and CH tests is good. You will be throwing away TA and CH tests and wishing you had more CYA tests. And the OTO chlorine test is very handy for day to day testing. I love my tf100 case. And you get to buy discounted refill kits in the spring.
    chopshop's Avatar
    Aug 2015
    Florence, AZ
    34
    Quote Originally Posted by YippeeSkippy View Post
    Does this device come with the kit or is it an add-on?
    So, I'll be doing my "daily" tests for chlorine with the chlorine OTO?
    Jan 2012
    7,306
    It is an add on. Worth every penny, IMO. I didn't get one at first but now that I've got it I won't go without!
    You may or may not be using the OTO...it only goes up to 5ppm, and sometimes some folks keep their pools up above. But its excellent for confirming the presence of chlorine even if you're not getting the exact number.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Ok let me give an example of how the TF-100 is better than the K-2006C
    The FAS-DPD FC/CC test process uses R-0870 powder, R-0871 drops and for the CC portion also R-0003 drops
    The standard TF-100 includes 1- 10 gram jar of R-0870 powder, a 60 ml bottle of R-0871 and a 22 ml bottle of R-0003 drops for the CC test.
    The XL options doubles the amount of R-0870 and R-0871
    The K-2006C includes 1- 10 gram jar of R-0870 powder, a 2 ounce (60 ml) bottle of R-0871 and a 2 ounce (60 ml) bottle of R-0003
    Now at first you are going to notice that you have a bigger bottle of R-0003 with the K-2006C, and you will think this is a good thing, when in reality it is excessive, because anytime you do a FC/CC test you will only use 5 drops of R-0003, where you will use 2 drops of R-0871 for every ppm of FC or CC in your test sample, plus one drop each to confirm the color change has stopped.
    So lets say you are running a typical pool with 40 ppm CYA, and an FC target of 5 ppm, and all is perfectly on target, your test will use one tiny scoop of R-0870 powder, 11 drops of R-0871 for the FC test for a reading of 5.0 ppm, 5 drops of R-0003, then an additional 1-2 drops of R-0871 for a total of about 12-13 drops R-0871 and 5 drops of R-0003 used. This is a best case scenario if you were running a higher CYA, your FC would also be higher and use more R-0871, if you were fighting algae and performing a SLAM procedure with a CYA level of 40 ppm your target FC target level would be 16 ppm, plus you would likely have some CC present, and you would be using 34+ drops of R-0871 and still only 5 drops of R-0003. So while the K-2006C may give you those nice neat matching size bottles, it is not something you necessarily want once you get into doing the testing.
    Ike
    p.s. I too recommend the Speed Stir, I don't think anyone has ever regretted spending the money on it, but I will say those that have done the test all by hand particularly all the hand swirling on the CH test, are the ones that are the most appreciative, so decide either buy it now and think oh thats nice, buy it later and think oh how did I ever live without this, or don't buy and and do things the hard way.
    Jul 2015
    Western NC
    115
    I also recommend getting the SpeedStir right away. Also, having one vial for each (drop) test and one SpeedStir bead for each vial is useful.
    If memory serves me, the TF-100 comes with two vials and the SpeedStir comes with one bead. So if you're like me you'll want one extra vial and two extra beads.
    I also have a bead for the salt test (which came with a vial) but in retrospect that test seems like a waste of time and money, at least once you get the level right and that doesn't take very long.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    chopshop's Avatar
    Aug 2015
    Florence, AZ
    34
    Excellenct advise here, I'm heading to the TFTest website after completing this post to order up the TFTestkit along with the speed stir. Thanks all for the "arm twisting"!
    chopshop's Avatar
    Aug 2015
    Florence, AZ
    34
    Done, TFT kit and speed stir on it's way.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Quote Originally Posted by chopshop View Post
    good deal, you get more reagents and tests with it compared with the taylor test. and for LESS money, whats not to love?!
    welcome to TFP by the way
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2015
    N Tonawanda, NY
    469
    You won't regret it! Received mine in June & can honestly say I've never had such a trouble free pool.
    BTW - I've had this pool for 19 years.
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
