Results 1 to 13 of 13
Thread: total alkalinity constantly drifts lower...why?
    Aug 2015
    California
    6
    I have a 21,000 gallon in-ground pebble-tec combination pool/spa in hot central California, open year-round uncovered, that is 4 yrs old and has been managed since day 1 with unstabilized liquid chlorine. I've never had a non-clear day and overall have had very good balanced water. I constantly struggle though with a battle between pH and total alkalinity, every 10-14 days the pH creeps up to 7.8 at which point I add half a gallon of acid and it goes down to 7.2 or so, and slowly creeps up. In addition, the total alkalinity seems to want to live at around 60...I add baking soda every 2-3 weeks and can get it up to my target of 80 but this makes the pH go up faster to the 7.8 level at which point I have to add acid...so it's a constant see-saw between adding acid and adding base. I've got to the point where I'm ready to stop worrying about total alkalinity being at 80 and just leaving it at 50-60, and just keeping the pH in the normal range with a little acid every couple weeks.
    Any thoughts or suggestions on this? My other levels are within normal limits. This is the original water in this pool.
    Wildcat's Avatar
    Jun 2013
    309
    Re: total alkalinity constantly drifts lower...why?
    What's your CH? 60 TA can work with 7.5 PH. Check the CSI index in Pool Math
    I have high CH, 460, and live with 60-70 TA to keep CSI low
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    Welcome to TFP!
    First, how are you testing? Are these your numbers or from a pool store?
    Do you have any water features like waterfalls or sheer descents? Aeration causes pH to rise, so if you have a source of aeration, this may be why your pH tends to rise.
    Support the site
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Follow what YOUR pool is telling you. If it likes TA around 60, then so be it. Mine does too.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Welcome to TFP!
    Aug 2015
    California
    6
    Quote Originally Posted by Wildcat View Post
    My CH is around 400.
    Quote Originally Posted by tim5055 View Post
    Welcome to TFP!
    I'm testing carefully with a Taylor k-2006 test kit. I do have both a 2 foot spill-over waterfall from spa to pool (it's smooth water that I think doesn't aerate much but maybe I'm wrong) that runs ~6 hrs day and 3 jet fountains that shoot from the deck up and into the pool and run rarely, like 1 hr/week.
    30,432
    You have a good grasp of your pool water management. I agree you should let the TA find it's own level.
    DFW, TX
    24,517
    You will be fine with TA at 50-60 and PH 7.5-7.8.
    Aug 2015
    California
    6
    Great, that makes me feel a lot better. I was concerned that leaving my TA at 50-60 was somehow a bad thing, but it certainly does want to live at that level. And maybe it is the aeration from my spillover that causes the pH to slowly drift up..the pH is easily manageable though, it's the TA that's been stressing me.
    Wildcat's Avatar
    Jun 2013
    309
    Quote Originally Posted by eye.surgeon View Post
    As I mentioned, use the CSI index in pool math,it will give you comfort
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, increased aeration outgases carbon dioxide faster and that causes the pH to rise faster, but note that lower pH also does that so you don't want to lower your pH too much. Your acid addition is what lowered the TA over time so not needing to add as much acid will lessen the rate of TA dropping. So finding a lower TA level for more pH stability and targeting a higher pH level is fine. Because of your plaster surface, you can increase your CH if needed to have the CSI not be too negative.
    Sep 2014
    Bakersfield, CA
    155
    I have the same problem with rising pH, I eventually found that the pool would hold at 7.8 for another week or so and then slowly rise. So now I wait until the pH rises to 8.0 before adding acid, and add enough via PoolMath to take it down to 7.6. It's now about three weeks between acid adds, down from every week previously.
    Cheers, Peter
    20,000 gal, 52'x17' kidney shaped IG, Pebble Tec, IntelliPro P6E6VS4H-209L pump. Intellichlor IC40 SWG.
    300 sf Sta-Rite System 3 cartridge filter. Poolvergnuegen 4-wheel suction pool cleaner. TF-100 test kit.
    Aug 2015
    California
    6
    Thanks for the suggestions.
