Results 1 to 11 of 11
Thread: Cloudy water after brushing but no CC present.
    Jul 2015
    Canada
    12
    Last week for the first time Since May I brushed the floor of the pool and could see lots of green clouds being formed by the brush stroke. My understanding is that this is algae, I poured 10 litres of liquid chlorine into the pool last night and waited 24 hours to test the water while keeping the swg on super chlorinate. I tested the water today and the results are below. the water is still cloudy but the results show no CC... I am wondering what the problem could be?
    FC: 2.4
    CC: 0
    PH: 7.2
    TA: 100
    Salt: 3050
    CH: 210
    CA: did not test as no stabilizer was added this season to the water.
    Any suggestions?
    40k gal, IG gunite, Pentair Sand filter, hayward superpump, K-2006 Test kit. Hayward T15 40k SWG.
    Jun 2014
    15,255
    Re: Cloudy water after brushing but no CC present.
    Your problem would almost immediately appear to be that you have a very low FC level for sanitation, coupled with no CYA (stabilizer) to protect the FC. Therefore, the sun will oxidize your FC right away each day. Your SWG must be working overtime as well. You really need to add stabilizer then prepare to do a "SLAM" to remove the algae. The SLAM link is in my signature below. Use the Poolmath calculator to add enough CYA for a target of 30ppm, then start your SLAM as soon as you can following the link below. Follow that page carefully.
    After you complete the SLAM, you should increase your CYA to the recommended 70-80 for a SWG pool. Hope this helps.
    Donldson's Avatar
    NW Ohio
    2,917
    You are running an SWG without CYA in your water? Well your problem is algae. Without CYA your SWG is producing chlorine that is destroyed quickly by the sunlight.
    You will need to SLAM your pool. Why haven't you added CYA to your pool, especially with an SWG?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2014
    15,255
    Oh, and just to be clear, you can in-fact have algae with zero CC present. The SLAM will fix your problem.
    Aug 2015
    San Antonio/Texas
    2
    Having similar problems and I have had to shock the pool, run the pump overnight, use the drains to recycle more than the skimmer, and add some fresh water. All of that and the greenish yellow powder, algae, is finally almost gone. I've also used some algae treatment from Leslie's which wasn't as effective as the other steps. Hope this helps.
    'Dave' Fiber Glass, 16' by 32' 16,000 gallon, In Ground, Hayward Sand filter, Pump on timer
    Jul 2015
    Canada
    12
    I never added stabilizer this season and never had any problem with any sort of algae growth so based on that I did not see a reason to add it, only problem was that I brushed the floor recently and it made it cloudy. will do the slam and see where it gets me.
    Donldson's Avatar
    NW Ohio
    2,917
    Jun 2014
    15,255
    Based on your location, temperature, and the amount of sunlight your pool receives, that could explain why you have been fortunate to not need stabilizer, but that is typically quite rare unless someone has total shade or in indoor pool. Good luck on your SLAM. Follow those instructions carefully and you should be fine.
    Sep 2013
    Connecticut
    728
    Actually, not adding stabilizer this season does NOT equate to 0 CYA in the water - please measure current CYA levels before anyone considers how much CYA to add to the pool.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Jul 2015
    Canada
    12
    Quote Originally Posted by singingpond View Post
    I measured cya and it was zero. there is really no point to add it at this point as the pool will likely be closed mid September (the latest).
    Mar 2007
    San Rafael, CA USA
    12,082
    With no CYA to moderate chlorine's strength, the active chlorine level will be quite high unless you keep your FC exceptionally low which is hard to do in sunlight. So if you plan on using the pool, just be aware of that. Even 1 ppm FC with no CYA is over 15 times higher in active chlorine level than the minimum FC/CYA level we recommend. So 1 day in such a pool with 1 ppm FC and no CYA is like being in our normal pools for 15 days.. Your swimsuits, skin, and hair will get oxidized that much faster. Taken to extreme (which I know you wouldn't do) it could be unhealthy as noted in the thread Chlorine Poisoned and pregnant, how bad is this?.
