Page 1 of 11 1234 ... LastLast
Results 1 to 20 of 218
Thread: New Build In Simi Valley
    Aug 2015
    Simi Valley, CA
    87
    We have been working with our pool builder for about two months now to get our pool and backyard design and now we are finally starting. Friday was the first day of demo but it was more of a set up day for the demo crew. Here are some pictures of the design and the yard before demo. I like everyone else on this forum have learned so much from the great people here. I am very excited to get this pool built just so I can use the TFP method. I will keep you updated as we move forward and look for help when we run into issues (I hope there are none).
    Build estimated completion October 2015, IG 21500 gallons, Agua Blue Pebble Tech,1xPentair Intelli Flow VSP, 1x3HP waterfall and slide pump, Pentair 520 soft cartridge filter, Nature 2 purification system, Pentair 400,000 BTU heater, Polaris 9550 Sport, Taylor K-2006.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: New Build In Simi Valley
    Welcome to TFP!
    If you plan to follow our methods you can have the builder leave out the Nature2 or don't add mineral packs to it. Do a quick search on Nature2 here and you will find they are nothing more than a higher priced puck dispenser with added copper. If you are having water problems in your area one thing you don't want is the copper from the mineral pack or the stabilizer/CYA from the chlorine Nature2 uses.
    Support the site
    Aug 2015
    Simi Valley, CA
    87
    Hi Tim. Thanks from all the reading I have done on the site my plan right now is to have them install but I won't use it. I will probably use the chlorine side for when we are gone on a vacation.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Bing125 View Post
    i could be wrong, but I don't think the Nature2 uses standard 3" pucks, so you are stuck with their higher priced stuff.
    Having an erosion feeder for vacations and such is a good idea if you have the CYA overhead available. But, in that case I would just go with a standard 3" erosion feeder rather than the Nature2. You can pick up standard 3" tricolor pucks at Costco or other big box stores a lot less expensively.
    You will find that in some cases pool builders push certain items because they get them free, discounted or even a kickback so you end up using the higher priced product.
    Support the site
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,532
    OH I am in on this one! This is going to be pretty!
    Kim
    Aug 2015
    Simi Valley, CA
    87
    Thanks Kim. More pics tomorrow after a real day of demo.
    Aug 2015
    Simi Valley, CA
    87
    Excavation complete. Tomorrow digging begins.
    Jul 2012
    Tallahassee, FL
    30,532
    And so begins! FUN but oh so dirty!
    Kim
    Aug 2015
    Simi Valley, CA
    87
    So real week 1 done and they have almost got the pool dug out. Next week they finish the dig and then start plumbing and steel. In two weeks we will have gunite. The only SNAFU for this week was they had to cut the water to the front yard because it runs around from one side of the front, through the back to the other side of the front. Called the project manager and he was at the house in 10 minutes working on the problem. He is going to have his guys hand water the front for me until they can get the plumbers in next week.
    Demo
    The Dog thinks the big hole in the backyard is for him.
    This is the view from where the slide will start. PB said he will have to be careful about how much sealer goes on it to make sure it is not TOO FAST!
    [/URL]
    This is the current state. They have a couple of more days of digging and then on to steel and plumbing.
    Jul 2012
    Tallahassee, FL
    30,532
    Great start! So nice he stepped up for the cut pipe! NICE!
    Kim
    Jan 2011
    Richmond, Texas
    595
    That is going to be an awesome pool!
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Aug 2014
    Houston tx
    2,524
    This is another ginormous pool! I guess that's what you put in a ginormous lot!
    Can't wait to see that slide!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    That slides is just the ticket for your lot!!
    oh, and dog = adorable, s/he's going to be happy with the pool!
    Aug 2015
    Simi Valley, CA
    87
    So the pool dig is complete and so far no major problems. PB says they will be doing steel and plumbing tomorrow and getting it inspected on Monday. I think he forgot Monday is a holiday so I am expecting inspection on Tuesday and gunite on Wednesday of next week. So far no major problems (knock on wood). PB has been great and I even came home tonight to them hosing off the driveway of the dirt they have made from moving dirt.
    Everything is dug.
    View from the top at the slide entrance.
    Sep 2012
    Los Angeles
    99
    That is going to be one amazing pool when you are done!
    Rectangular pool 28x16 and spa 8x7, 17,000 gallons, IG, Tropics Blue Mini-Pebble, Jandy 60 DE filter, saltwater cell, Jandy VS pump, 1.5 hp Jandy spa pump, 400k heater, 5' Sheer Descent with 1 hp Jandy pump, Jandy color LED lights. Build Thread
    azwaldo's Avatar
    Aug 2015
    Phoenix
    70
    Nice. That Excavation dig has got to be the PB biggest expense with building your pool. Some hard rock and solid layers i see there when they were digging. Plus the slope going up. Here in AZ, a pool can jump up in price drastically just on the type of foundation (soil or rock) you have and even more with a slope on a hill or mountain.
    Can's wait to see your build in progress.
    NEW POOL BUILD IN THE WORKS. :)
    PLAY POOL - SPA- SUNKEN BAR
    Jul 2012
    Tallahassee, FL
    30,532
    WOW! That is some dig! Such skill!
    Loving watching this!
    Kim
    Jan 2015
    Austin, TX
    1,095
    I am a little envious of the slide! Awesome way to use the slope of your lot. I might just have to put a slip and slide down my hill into the pool after seeing this build.
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    Aug 2015
    Simi Valley, CA
    87
    Thanks all for the kind words. They are putting in steel today through Saturday. I will update some pictures tomorrow. A slip and slide would have been cheaper.
  20. Back To Top    #20
    May 2013
    Albany, NY
    59
    Incredibly skillful dig and amazing layout. I'm subscribing to this one for sure. Oh and btw, what a handsome dog!!!
    Eric Adams, Technical Specialist, Radiant Pools
