Thread: algae by tailspinj
    Jul 2015
    bucks PA
    1
    algae by tailspinj
    How much ppm does one gallon of liquid chlorine raise.
    TAILSPINJ
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: algae by tailspinj
    1 gallon of 8.25% bleach in 10,000 gallons of water will raise FC by 8.5ppm
    Divin Dave,
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Welcome to TFP!
    That would depend on the volume of the pool and the % of the liquid chlorine. With that information you can put your numbers in Pool Math (link above) and it will show the ppm rise down near the bottom under effects of adding chemicals.
    Support the site
