Results 1 to 7 of 7
Thread: Water leaking after so called repair
    Mar 2013
    TN
    178
    Pool guy had to come by and reinstalled jet cover after yours truly couldn't get it back on. Long story! I have been pumping 50-75 gallons out morning and night for four days. The jet is not screwed in all the way like my others are in the pool. Could that cause this issue? you can see in the pic that it is not screwed all the way in. Ideas?
    20x49 double roman 3.5' to 8.5 deep', 44,000 gal. SWG, TF-100 test kit with speed stir, concrete walls with vinyl liner, cartridge filter on an IG pool with a 1hp main pump and 1.5hp booster pump. Pool built April 2013
    Jun 2015
    Wildomar, California
    423
    Re: Water leaking after so called repair
    No, the jet fitting would not have anything to do with a water leak. It's for water direction only. But, if it was hard to get in, or screwed in crooked or wrong, it could have cracked the wall fitting. I've seen that happen. Has your pool started leaking after your PM put the fitting in?
    Mar 2013
    TN
    178
    It was leaking before then and they came once before and pumped it out then dumbbutt me took the cover off to clean behind it for potential algae growth and couldn't get but one screw back in so they came and put the cover back on. It has leaked ever since. I took the eye out this morning and it had a piece of the liner in the threaded. I trimmed it out carful lay and put the eye back in and it easily screwed back in all the way or at least further than it was. It did not over tighten it for sure.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Ok, let's hope that solved it!
    Mar 2013
    TN
    178
    Ok, the other pool guy came by yesterday and found that when the pool store guy put the cover back on he did not get it sealed properly. I put a patch over the jet hole and cut a new hole in it and reinstalled the jet and it fixed the problem. He shot dye in it to start with and it was leaking on the upper side of the hole, it was hard to see from above but that is no excuse for the pool store guy. Probably done with the pool store people.
    DFW, TX
    24,509
    Thanks for the update. Glad it got resolved. What a pain!
    Jul 2015
    Kentucky
    1,127
    So glad you got it fixed. Now you can focus completely on completing your Slam. So back to the other post we go, see ya there
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
