Thread: Phosphate effect on Taylor K-1766 chloride test
    Jun 2015
    Cedar Park, TX
    12
    The Taylor K-1766 "Potential Interferences" information states that orthophophate levels greater than 25ppm causes positive interference. Anyone know how much to adjust the result based on a phospate level that exceeds 25ppm? Mine tends to run 200-300ppm.
    15,000 IG Plaster
    Pentair TR-100 Sand
    Pentair IC40 SWG
    Pentair EasyTouch with ScreenLogic2
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Phosphate effect on Taylor K-1766 chloride test
    25 ppm is 25,000 ppb so hardly any pool has such levels. You do not have 200-300 ppm (parts-per-million); you have 200-300 ppb (parts-per-billion). We've only had one pool on this forum above 25,000 ppb and that was because of fairly massive amounts of HEDP metal sequestrant being used, far above normal usage levels.
    Jun 2015
    Cedar Park, TX
    12
    Quote Originally Posted by chem geek View Post
    Ugg. A good reminder of the importance of double checking units of measure. Thanks
    15,000 IG Plaster
    Pentair TR-100 Sand
    Pentair IC40 SWG
