Results 1 to 11 of 11
Thread: Which concrete surface to use for pool sidewalks?
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Brushed concrete vs Aggregate concrete, which is the slickest? Can you stain brushed concrete?
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Which concrete surface to use for pool sidewalks?
    Exposed aggregate concrete will be slicker than brushed concrete simply because the aggregate used is almost always small river rock that is polished and rounded. Those exposed rocks will be slicker than a brushed concrete surface. I don't think it would be overly slick for a pool decking surface but I've never experienced it first hand. Might depend on the protrusion height of the stones after the cement wash out procedure.
    Any concrete can be stained. You'll get the best results with a concrete that actually has the cement portion of the mixture dyed with additives rather than staining after the installation but both can be done.
    Isolated Spa - 345 Gallons
    JoyfulNoise's Avatar
    May 2015
    13,193
    All of our sidewalks to the pool decking were done in stained concrete with a rock salt finish. It looks great, especially when it rains and the color deepens a bit.
    Matt
    Jun 2011
    Long Beach, CA
    2,781
    I went with a rock salt finish and didn't bother with a stain as I don't want to have to seal it to protect the stained finish.
    Jun 2014
    Roseville, CA
    343
    I have rough exposed aggregate and it is like cheese grater.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    May 2015
    13,193
    Just to show an example, both the pool deck (acid wash finish) and the sidewalk (rock salt finish) used the same colorant in the cement mix. But they look different dry and wet. The picture below is dry, deck on top sidewalk on bottom.
    Matt
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    My whole deck is exposed aggragate and its even sealed, and I dont consider it to be too slick. I dont have brushed concrete, so I can't make that comparison.
    As chuckiechan put it, "feels like a cheese grater", well maybe not quite that bad, but after a few hours, you will need your flip flops, and not because of the heat, but your feet get sore from walking barefoot on it after a while.
    Divin Dave,
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Thanks all for the input. I want the aggregate and my wife want the brushed. Who you think will win.....HA!
    Mark
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Now wife wants just "regular" concrete finish. I've tried to explain to her how slick it will be, but she wont listen!!!!!
    Mark
    May 2015
    13,193
    Quote Originally Posted by kywildcats View Post
    At least try the acid finish. It's not slippery at all.
    Matt
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I like the acid finish. I like the 'weathered' look it gives.
    Divin Dave,
