Thread: AGP Closing..Drain or No Drain
    Aug 2014
    Spencer Ma
    32
    Hi all,
    This was my first swimming season with TFP and everything has gone great this season. Unfortunately we are getting close to close up for the season so I was wondering if using a metal face plate over the skimmer opening is ok instead of draining below opening... Last season I had a cheap foam insert that popped off at some point and I think that is what caused the winter damage to my pool last winter. Last winter was really hard here in Massachusettes and there were many AGP casualties...
    What are your thoughts?
    Jed
    27 ft round above ground Pool 17000 gallons with Haywood sand filter 1.5 HP
    cvgnus's Avatar
    May 2015
    Massapequa, NY
    46
    Re: AGP Closing..Drain or No Drain
    I do all of the above. I lower the water 6" below skimmer/inlet and cover the skimmer intake facing the pool with a metal cover that has a foam backing and plug the inlet. I have PVC piping so in addition I rinse all the pipes with clean water and blow out all with a shop vac. Then use either expanding rubber plugs or screw in plugs on all open ends of the piping.
    5900 gal Oval 17' x 12' x 54" Sharkline Navigator 54 AGP; 1.5 HP Hayward Power-Flo LX Pump; Hayward EC65A DE Filter; AquaComfort XL ACT-750 Heat Pump;
    Hasa 8 gal Liquidator;
    TF-100 Test Kit w/Speedstir
