Results 1 to 8 of 8
Thread: New to pool chemistry
    Jun 2015
    Alpharetta
    17
    I have a newly constructed pool with pebble finish (one week ago) and I am having difficulty understanding the proper pool chemistry. After running several tests, it indicates that I have a low total alkalinity (40). However, an acid demand test shows I need about 3 qt. of muriatic acid.
    From what I've read adding sodium bicarbonate will raise the total alkalinity but the adding additional acid in conjunction with sodium bicarbonate seems counter intuitive.
    Why would I need acid and sodium bicarbonate at the same time? Does this have anything to do with the newly curing pebble finish?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    Re: New to pool chemistry
    New finishes will cause the Ph to rise fairly rapidly until it cures up some. Are you brushing it as well?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Yes to all of that.
    It is important to keep your PH at 7.8 or lower at all times. Also, fairly important to keep your TA at 50-60. So, adding MA to lower PH and baking soda to raise TA is fine, even though it is a little counterintuitive. Enter all of your numbers in Poolmath and monitor your CSI score and be sure to keep it between -0.5 and +0.5. Is your CH above 250?
    Sep 2013
    Connecticut
    728
    Is your pool builder already leaving management of the chemistry to you at this point? Understanding what's going on is great, but you don't want to ignore the PB's instructions at this point, if there is a warranty involved.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Aug 2014
    Northern IL
    4,615
    Do you have a warranty with the pool builder? If so, you need to keep those conditions in mind.
    Jun 2015
    Alpharetta
    17
    Quote Originally Posted by woodyp View Post
    Yes, I'm brushing. How long would you suggest I brush? Days? Weeks?
    Sep 2013
    Connecticut
    728
    Pool School - Start-up New Plaster
    May be helpful to you.
    Jun 2015
    Alpharetta
    17
    Quote Originally Posted by singingpond View Post
    I don't have a plaster pool.
