Thread: New Pool owner
    Aug 2015
    Paramus, NJ
    2
    New Pool owner
    i got a 15' 42" INTEX vinyl a few weeks back. following are test numbers (tested on many days):
    FC is 0 : has always measured to zero.
    Ph has measured between 7.5 to 7.8
    TA has been 80
    TH has been 200 - 400
    CYA is 30 - 50
    Of all the above, FC has never changed. I have been using household bleach. The water looks good, have kept free of bugs, dirt etc.
    Appreciate your advise if I should put any chemicals (always am wary of using those ).
    -g
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: New Pool owner
    Welcome to TFP!
    You have come to the right place for advice in caring for your new pool.
    I'm going to make a suggestion. We have available a section called Pool School, linked on every page here. The getting started page is where you should start.
    For your FC, get a gallon of bleach, and start adding a little each day, following the recommendations in Pool School. You can use the calculator to determine the amount you need to add.
    Aug 2015
    TX
    66
    Re: New Pool owner
    I just want to add, this place is amazing! They are so much help. I'm learning so much here. I am a first time pool owner and was overwhelmed with what to do. Everyone here will guide you in the right directions.
    16,065 gallons IG, gunite, pump: Jandy 2.0 hp 2-speed, filter: Jandy 60 sq. ft. D.E. filter, automatic pool cleaner: Polaris 280, chlorination: Jancy Aquapure electronic salt water chlorinator
    Sep 2013
    Connecticut
    728
    Re: New Pool owner
    Those test results look like they are from test strips, which are notoriously unreliable. At the least, pick up an OTO test kit (drop test, with yellow for chlorine on one side, and red for pH on the other side. And read this
    Pool School - Guide for Seasonal/Temporary Pools
    added - Where did the CYA come from - have you put any chemicals, other than bleach, into your pool after filling with water?
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Aug 2015
    Paramus, NJ
    2
    Re: New Pool owner
    Thanks Charlie_R for your quick reply. I have been reading this forum and would continue. Thanks for your advice on FC.
    Hi RuthN, thanks for your the assurance. I also felt the place here has genuine advisers and perhaps not with commercial bias etc. thanks much.
