Thread: New Pool! Noob owner with test results
    Aug 2015
    CA, Sac area
    2
    Hello everyone, thank you for taking the time to give advice. Here are my test results using the Taylor K-2006.
    FC 1.6
    CC 0
    PH 7.4 - 7.6
    TA 140
    CYA 50-60
    CH 80
    I'm a completely new pool owner with a new pool and the pool training I received from my builder was a joke at best. Research has lead me to this site. I've been using 3" tabs in the auto feeder but my reading on this site has me thinking I should discontinue use pretty soon. I'm also concerned about my CH levels testing so low. Any advice on getting me off to a good start would be greatly appreciated.
    24,415gal in-ground, July 2015 - Gunite/Plaster/Colorscapes - Jandy Pro Series Stealth 2 speed pump(shpf) - Jandy Pro Series cartridge filter(cv460) - Rainbow Feeder - Zodiac MX8 cleaner - Taylor K-2006
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: New Pool! Noob owner with test results
    hi there, well you are lucky that your CYA levels are still manageable, but you should stop tabs right away. you don't want your CYA higher than where you are at. your FC is way too low. how does your water look?
    for your CYA, your absolute minimum FC level is 5ppm! see link:
    Pool School - Chlorine / CYA Chart
    you should target to hit 7 or 8 when you dose, so that when it goes back down it doesn't ever go below 5ppm. you need bleach in there asap
    yes, for a plaster pool like you need to get your CH up asap. you can pay 3x as much at a pool store, or order online at home depot, etc. this is from pool school:
    CH - Calcium Hardness
    Calcium hardness can be raised with calcium chloride or calcium chloride dihydrate. They are available in some areas as Peladow, Dowflake, Tetra Flake, or Tetra 94, often sold as a deicer by hardware stores, and some big box stores, in colder climates. Pool stores will carry either calcium chloride or calcium chloride dihydrate under a variety of names, including Hardness Plus, Balance Pak 300, Calcium Hardness Increaser, etc. Calcium products should be spread across the surface of the deep end of the pool.
    how does the water look? is it crystal clear? any cloudiness or visibile algae??
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    First things first. NEED MORE FC IN THE POOL! Refer to the CYA/Chlorine chart in my signature. You need to get the FC up to the recommended level for 60 CYA ASAP to prevent algae problems.
    Your CH is indeed fairly low for a plaster pool. I would test the CH of your fill water as well. You may be adding CH in your fill water and a new plaster pool will leech out some calcium after install. They gave you no instructions on starting up the pool or anything that you must do in order to maintain your warranty?
    Isolated Spa - 345 Gallons
    Oct 2014
    San Antonio, TX
    449
    Welcome to TFP!
    Free form 17X30. 14,500 Gal. Pentair sand filter and 1.5 hp pump. Aqua-Rite SWCG. TF-100 Test Kit w/Speed Stir
    Aug 2015
    CA, Sac area
    2
    Quote Originally Posted by DaninFLA View Post
    Quote Originally Posted by JVTrain View Post
    Yes I read the chlorine/CYA chart here. It's kind of confusing since various sources says ideal range for chlorine was 1.0 - 1.5 ppm or 2.0 - 4.0 ppm and chlorine above 4 ppm could cause irritation. I thought I was in the appropriate range. Water is crystal clear.
    My plan is to stop use of tabs and switch to bleach or liquid chlorine. I'll get my levels raised but i'd love to see some info debating these test kits or at least confirming chlorine above 4 ppm is harmless. Why is it stating 1.0 - 1.5 as being ideal? So confusing.
    My CH was never tested at start up. I received start up instructions but chemicals were never mentioned beyond testing FC, PH & TA. I'll raise my CH levels asap as well. Should I do this slowly over a couple of days?
    Sorry total noob here but i'm ready to learn
    Jun 2015
    Raleigh
    357
    Quote Originally Posted by LJay View Post
    Because you're reading the pool store mentality that doesn't take the science of CYA/Chlorine relationship into account. Continue to read and study here. Most of us keep our FC in the 5 to 7ppm range. With a CYA of 50 if you keep FC in the 2ppm level you will soon have algae. You are safe to swim in water up to shock level and for 50 CYA that's 20ppm FC. The first step into Trouble Free maintenance of your pool is to quit listening to the pool store and study the science of pool care here in the pool school links. As long as you keep trying to reconcile the TFP science with Pool Store hocus pocus then you will remain confused.
    The science: http://standards.nsf.org/apps/group_...lorine-CYA.pdf
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
