Results 1 to 10 of 10
Thread: Is it just the leaves - pH question
    Nov 2012
    Dallas, TX
    46
    All summer my pH has been rock-steady at 7.8. 20k gallon bleach pool, I'd add a cup of MA maybe once every couple of weeks.
    I've got two sycamores by the pool and it is one of the 4 shedding times of year.
    Will leaves really Jack the pH that much, or do I have something else to investigate?
    Since that started, I'm needing about a cup a day of MA to stay at 7.8. Chlorine consumption has gone up slightly, but if expect that.
    TA is stable at 70, CYA is stable at 40. CH around 200.
    Currently
    6.0 FC
    0.4 CC
    7.8 pH (acid already added today)
    70 TA
    40 CYA
    200 CH
    Obviously the water is crystal clear and the envy of the neighborhood
    ~21,000 Gallon Kidney Shaped Plaster Pool
    2 feet shallow to 8 ft deep end
    Only one skimmer, and two return jets plus Polaris 280 Jet
    Dallas, TX - West Side of House = HOT
    48 SqFt DE Filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Is it just the leaves - pH question
    I really do not think leaves are raising your pH. What is your makeup water TA and pH? Have you changed Chlorine sources? Has anything else changed?
    Essential Links:
    Nov 2012
    Dallas, TX
    46
    I haven't added any water and we haven't seen any rain, but Dallas city tap is 8.2 pH, 40 TA
    Chlorine is 8.25 bleach, usually Costco chlorox 3 packs, but sometimes target.
    Nothing has changed except leaves that I know of.
    I was out of country last two weeks, but my wife diligently put in 1 gallon per day as instructed. She didn't test, though. Over 100 degrees 1 gal per day is about my normal consumption.
    48 SqFt DE Filter
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    I dunno about sycamore trees but oak trees and their constituent parts (leaves, acorns, branches, etc.) do have tannins within and leach tannic acid when soaking in water...like a pool, for example.
    My brand new pebble sheen finish shows a brownish stain surrounding oak tree parts but thankfully, the chlorine oxidizes the stains PDQ as long as I pull the source(s) out daily. I was initially horrified and dove in and scrubbed scrubbed to not much effect but low and behold the next day, the stain had faded away! Since then I no longer worry.
    Anyway, take a handful of tree droppings and put them into a bucket of pool water whose properties you know well and then test the water several hours or a day later and see what has changed. It might be a clue. If I do that with oak droppings, the water turns a very dark brown. In fact, it makes a nice wood stain.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    30,414
    I do not know for a fact but I bet you will find the leaves are acidic
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    sycamore leaves are slightly acidic according to gardening websites.
    So your pH would go down if anything.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Jul 2015
    Kentucky
    1,125
    8.2 pH for city water seems very high to me. At least high compared to most of ours. I think the majority of the members fill water is pH of 7, but if you've not added since the increase started that wouldn't be the culprit.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    Jul 2015
    Kentucky
    1,125
    I just read on a site called freedrinkingwater.com that the normal pH for drinking water should be between 6-8.5, so I guess most of the members pH is just softer water than yours.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You had to have added some water, especially with the warm temps we've been having. Either that, or your pool must be very low with no rain added either.
    Essential Links:
    Nov 2012
    Dallas, TX
    46
    Found the culprit I think. While I was traveling a bottle of low splash bleach was accidentally added to the pool.
    Only noticed as I was cleaning up my pile of recyclables for trash pickup.
    I'm assuming they use something very alkaline to make it low splash.
    48 SqFt DE Filter
