Results 1 to 7 of 7
Thread: PH/TA adjustment
    Aug 2015
    Plainfield, CT
    4
    PH/TA adjustment
    I am new to the forum and have just started testing and using the pool math. My test results are:
    6.6 FC
    7.0 PH
    130 TA
    450 CA
    60 CYA
    My question is regarding the relationship between PH & TA
    Pool Math says "to add 186oz by weight of washing soda or soda ash to raise PH to 7.5"
    Then for TA it says "To lower TA you reduce pH to 7.0-7.2 with acid and then aerate to increase pH.
    Note: Adding baking soda will also raise your pH just a little"
    How do I lower TA to 80 and raise PH to 7.5?
    Thank-you
    Byron
    Foxx18x36 IG vinyl; 25000 gallons;Ecofilter E5 315# Zeolite filter, EcoPump EP-4 1 / One HP Swimming Pool Pump 2speed http://www.ecopoolfilters.com/; Circupool Si+45 PLUS Complete Salt PoolSystem; http://www.circupool.com/; Jandy LRZ250EP Legacy LRZ 250,000 BTU; TAYLORK-2006C Swimming Pool/Spa LiquidTest Kit
    Jun 2014
    15,217
    Re: PH/TA adjustment
    Hi Byron. Whenever someone needs to lower TA, it's with muriatic acid. Of course that also lowers pH. The trick is to do it carefully "in stages" so that when you add acid, you only lower pH to about 7.0, then you aerate the water which raises pH ONLY and leaves the TA alone (lower). Make sense?
    Also keep in mind though, a good pH is really your primary goal. No need to get too picky with TA if your pH stays within the 7.2-7.8 range.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    You don't need to add anything at the moment. Just aerate. Point returns up to break the surface. Build an aerator. Encourage the kids to have a splash fight. Anything to churn the water up good. The pH will rise. When it rises to 7.8, add acid to lower pH to 7.2 and that will lower the TA as well.
    TA is the least critical of all the parameters. Don't obsess over it.
    Mar 2007
    San Rafael, CA USA
    12,082
    By the way, the abbreviation for Calcium Hardness is CH. We don't use CA because that can be confused with Cyanuric Acid though that is usually written as CYA to again avoid confusion.
    Aug 2015
    Plainfield, CT
    4
    Thanks for the info. PH is up to 7.5 today from aeration.
    Aug 2015
    Plainfield, CT
    4
    Quote Originally Posted by chem geek View Post
    Thanks, it was a typo........
    38,460
    Just to add, there is generally no reason to worry about a high TA. All it impacts in how quickly the pH rises. And if you keep the pH in range, that is about all that matters and the TA will slowly come down on its own.
