Results 1 to 10 of 10
Thread: From plaster to swim... how long?
    Eddd's Avatar
    May 2015
    Frisco, TX
    53
    Hey there! My pool build is nearing completion, pavers are going in now. They are doing plaster (WetEdge, Bermuda Luna Quartz) after cleanup and sod - which I hope will happen by Friday, 8/28.
    My question is this: once the plaster/water is in, I know there is a week of low PH and start-up activity; but will the plaster be fine right after that? Assuming this all happens to plan, and we get the chemicals balanced - I plan to waste no time and throw a pool party - hopefully on Labor Day! Unless this is a terrible idea.
    Thanks for your input.
    About to build an in-ground free-from gunite pool in the back yard (no spa). Currently estimated at 19,000 gallons. Likely going with a SWG.
    38,242
    Re: From plaster to swim... how long?
    Wasn't this exact question asked within the last week?
    Ignoring the chemistry, the plaster should be fine by the time it is filled.
    But, depending on how they start it up (ideally but rarely a bi-carb start-up) ... usually acid start up, you may need to wait for the pH to be reasonable.
    Plus you want to be sure the plaster dust is filtered out.
    Eddd's Avatar
    May 2015
    Frisco, TX
    53
    Whoops -- my apologies, I did look, but just browsed... I should have done a search
    My understanding is exactly what you said -- basically after the week of 'start-up', as soon as the chemistry is good, it's on like Donkey Kong!
    Thanks!
    38,242
    No worries.
    Really you need to follow the directions from the builder for warranty purposes ... Although they may not match our recommendations.
    Eddd's Avatar
    May 2015
    Frisco, TX
    53
    true... good tip, thanks again!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    We were in the pool before it was full and had a big ol pool party the following weekend.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    My PB told me that once the water hits the tile line to jump in, unless I was scared of my own bathwater They started the pumps the next day, did chems a couple days later. We swam the entire time.
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
    Eddd's Avatar
    May 2015
    Frisco, TX
    53
    thanks for the replies all!
    I will follow guidance from my PB, but I wanted to know the "real expert's" thoughts!
    Jul 2014
    New England - MA
    310
    Check our build pics. Our PB said it was ok to be in as it was filling. Have plenty of pics of or kids standing under the water truck hose!
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    Eddd's Avatar
    May 2015
    Frisco, TX
    53
    sweet -- thanks!
