Thread: Expansion Joint for New Construction
    Aug 2015
    Central, NJ
    142
    Hi all,
    I'm currently having a gunite pool built. This week, they're installing a paver deck around the pool. I had them do an expansion joint between the pool's coping and the decking, to play it safe and protect vs. future issues with shifting, losing tiles, etc.
    What is the best practice regarding sealing the joint? Should I immediately seal it? Or should I wait a certain amount of time? I wasn't sure if doing it immediately would be bad (i.e. if I should be letting the decking settle first).
    As far as sealing it goes, I looked around online at various reviews and options and I think I'm going to go with Sikaflex self-leveling polyurethane sealant since it has pretty good reviews and I can get it from the local big chain. Anyone have experience with this? Or does anyone recommend something different?
    Thanks in advance for any advice!
    In-ground 47'x25' free-form gunite pool w/ spa w/ waterfall. 35,380 gallons. 3' to 8' deep. 96 sq ft 6" deep sun shelf. SunStone Select Quartz Finish (Graphite). 2 Hayward skimmers. Jandy DEV60 DE Filter + Pro Series Plus 2HP Pump. Polaris PB4-60 Pressure Cleaner Booster Pump. Raypack P-R406A Heater. EasyTouch 8. IntelliChem w/ Acid Tank. IntelliChlor IC60. Techo-Bloc bullnose coping + Blu 60 mm paver patio. Merlin SmartMesh cover. TF-100.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Expansion Joint for New Construction
    The sikaflex is good stuff. I used it in the control joints I cut in my deck.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Seems like my PB waited a few weeks to add the seal.
    Corleone's Avatar
    Aug 2014
    Menifee/CA
    194
    Sikaflex is great stuff, that's what I used.
    13K Gallon IG Pool/Spa -- First time pool owners -- Completed in 2015 Caribbean Blue Pebble Tec Pentair 4000 Series 47 sq. ft. D.E. Filter Pentair IntelliFlo Variable Speed Pump Pentair SWG Jandy LXi Heater 400,000 BTU S.R. Smith Typhoon Slide Pentair LED 12v Lights Dolphin Nautilus Robotic Cleaner TF-100 Test Kit
    Our Build Thread
    Aug 2015
    Central, NJ
    142
    Thanks for the comments. I bought the Sikaflex. I'm going to wait a few weeks to do it, just in case any settling needs to happen.
