Results 1 to 7 of 7
Thread: Need A Little Clarification
    Aug 2015
    Bluff City/TN
    2
    I have slammed my pool and chemistry is great.
    I test my free chlorine in the evening after the sun sets and usually get a level of 5 (my goal for CY is 6).
    I usually put 1 gallon of bleach in every night to raise the level to 10 and by the next day it will usually fall to about 5 if the sun has been out.
    This just seems like a lot of bleach and chlorine to be using.
    Does my method seem reasonable?
    Is the amount of bleach reasonable?
    38,370
    Re: Need A Little Clarification
    Welcome to TFP!
    That is an excessively high FC loss every day. Can you post a full set of test results?
    Did you pass the three criteria to stop the SLAM process?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    Please add your pool info to your signature, more here, Pool School - Read This BEFORE You Post
    Aug 2015
    Bluff City/TN
    2
    FC - 5.8
    CC - 0
    pH - 7.5
    TA - 100
    CH - 260
    CYA - 55
    It did meet all criteria. Got the clearest water ever. No combined chlorine and passed overnight test.
    15,000 gallon above ground vinyl liner
    Pentair 1HP
    Hayward sand filter
    Taylor TF-100
    DFW, TX
    24,502
    What about cleaning out behind lights, under ladders, in cleaners, pool toys or other places where algae likes to hide?
    Aug 2014
    Northern IL
    4,615
    That is sage advise. You can have hidden algae that creeps into the water from hidey-places slowly enough that your FC kills it and no CC shows up leading you into a false sense of security. Been there. Try under your weir too.
    38,370
    I was guessing low CYA. Apparently not. Might try another OCLT.
