Results 1 to 10 of 10
Thread: New pool owner-(older pool)
    Aug 2015
    Frisco, TX
    5
    Hello, first time pool owner here and have some questions. I am taking my water sample to Leslie's every week for testing. My chlorine levels are always good (mostly FC4 TC4) so I have turned down my Chlorine production percentage. Water is always crystal clear. But now I am noticing that the walls and floor are changing colors. Some spots look splotchy green, some areas look splotchy white, and some areas splotchy brown. I shocked it and no change. Added algaecide today and no change. Anyone know what's going on?? Help
    current reading:
    tc 3
    tc 3
    ch 270
    cya 70
    ta 90
    ph 7.8
    pics are below
    17,000 gal IG salt water pool, DE filter,
    Aug 2015
    Frisco, TX
    5
    Re: New pool owner-(older pool)
    Owners manual calls it colored plaster
    Mod Squad pooldv's Avatar
    DFW, TX
    24,460
    Welcome to TFP!
    You have algae growing in your pool due to insufficient chlorine levels. Chlorine must be maintained above the minimum level for your CYA at all times to keep your pool sanitized and algae free. Chlorine CYA Chart
    To kill the algae you will need to follow the SLAM process, Pool School - SLAM - Shock Level And Maintain, which requires a great test kit. I use the TF100 from TFTestkits.net. More here, Pool School - Test Kits Compared
    Also, have a look at these articles from Pool School
    Pool School - Water Balance for SWGs
    Aug 2015
    Frisco, TX
    5
    Thanks! I had no idea the 2 numbers (cya and fc) correlated. Thanks for your help. Off to SLAM
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,428
    Before you can SLAM you need your own test kit. You really need the TF-100 XL as you will run out of the stuff you need to do a SLAM.
    You are going to need to test your water many times a day..........most pool stores get the tests wrong. Yeah I know they do it for free but is it really free if you are adding more stuff than your pool really needs?
    Kim
    Jun 2014
    15,027
    In addition, you probably should avoid those pool store chemicals as they tend to increase CYA or (like many algaecides) add copper. But also have to ask ..... in Frisco, are you on a well or city water?
    Totally agree about the TF-100. I have one and it's fantastic. Also ask for the "Speed stir"!
    Aug 2015
    Frisco, TX
    5
    City water.
    Where should I get chemicals?
    Jun 2014
    15,027
    Many of the chemicals you see mentioned here at TFP are easily obtained at your grocery or local home improvement store. For us in TX, I use Wal-Mart's "Great Value" or HEB's "Bravo" bleach. You can also get granular stabilizer from Wal-Mart. You can get muriatic acid from Home Depot, Lowes, or if needed the pool store. The pool store is fine for some things when you know what you want. It's the new pool owners that can easily be convinced by the clerk they need something new ( and expensive).
    Aug 2015
    Frisco, TX
    5
    That's me. They see me coming and I always leave spending at least $50. ��
    gamerasian's Avatar
    May 2015
    edison/nj
    85
    I am new pool owner too but what I have learnt in few months- don't trust the readings of the pool stores.. Do a one time investment and buy a good testkit it will save u money in long run.. Good luck with the new pool ..
    24k IG vinyl , new (not any more)pool, new ( not any more) water Hayward super pump and sand filter.
