Thread: How much Acid?
    Feb 2009
    North East Thailand
    How much Acid?
    Hello Folks
    Test results: -
    FC 16
    CC 0
    TC 16
    pH 7.2
    T/A 210
    CH 350
    CYA 100 or more!
    I have a 78000 liter pool, In ground, Tiled, Sand Filter,2kw Pump
    I need to lower the CYA levels and have at last been able to buy Hydrochloric Acid as advised, how many liters should I use and how often?
    Thanks for all your previous help
    Mike Court
    In ground Pool size 12m x 5m x 1.3m av
    Concrete construction with tiled base and sides
    750 Sand Filter
    1.5k Pump
    I don't have a skimmer, around the perimeter of the pool is a plastic grate above a concrete channel that directs overflow into holding tank.
    Re: How much Acid?
    The only practical way to lower CYA is to replace water. It would be best if you took care of that before thinking about the acid.
    Your primary need for acid is going to be because of your very high TA level. You should read Lowering Total Alkalinity at Pool School for instructions.
