Results 1 to 7 of 7
Thread: Smell at Pump - Not Running
    SPKNout4CHRIST's Avatar
    Mar 2011
    Goldsboro, NC
    210
    I noticed my water not circulating today so I went over to the pumping station and the pump was not running. I smelled a burning smell. The pump will not turn on. When I try to turn it on it sounds like it clicks, but nothing happens. Not 100% sure if that is the pump clicking or it tripping the breaker...
    Any ideas? Has it bit the dust? I am not sure on the age, although I would guess at least 8 years old if not older.
    Thanks and God bless!
    -Matthew
    22,600 gal. Vinyl Inground, FNS Plus 60 DE Filter, WhisperFlo 1HP Pump, SWG, Dolphin Nautilus
    Mar 2011
    Goldsboro, NC
    210
    Re: Smell at Pump - Not Running
    I went back out and tried turning it on and it sounded like the pump was in a bind and trying to run. I took out the pump basket (with the power killed to the pump) and reached inside of it and turned the impeller. I then reassembled it and turned it on again. It still sounded like it was in a bind so I tapped the top of the pump and it started running. Does that help any with a diagnosis?
    I'm afraid you're going to have to disassemble it in order to find out what's binding it,
    If you don't notice any visible damage in the impeller area, it's likely a bearing issue.
    If you have already smoke checked the motor, you may want to save your pennies, because even if you make repairs, you may be replacing the motor in the near future.
    24k gallon inground vinyl liner pool, 8'-3' depth, 2 skimmers, 3 returns, basic 5 chem kit.
    Hayward: DE-60 filter, Superpump VS, AquaRite salt chlorinator w/T-Cell 15, TigerShark QC robot. Jacuzzi hot tub ~350gal. Air blower type, w/8 jets.
    I would suspect the run capacitor on the top of the pump. It's probably about 30 MFD (microfarads).
    Support the site
    Jul 2015
    Winter Garden , FL
    46
    Check the contactor in the motor as well, sounds like an electrical issue to me rather than mechanical.
    Mar 2011
    Goldsboro, NC
    210
    Good news! I grabbed the capacitor out of the pump this morning and had it checked at an electric motor shop. It tested as being bad. I went ahead and got a new one from them for $22 and we are back up and running! Thanks for the info and suggestions everyone!!
    Good job. Thanks for the update.
    Support the site
