Thread: Storage....
    ThatDrunkGuy's Avatar
    Jun 2015
    Lake Forest, CA
    10
    Storage....
    ....quick question. I have my muriatic acid out in a storage box with my equipment. I wanted to raise my CYA a bit, so I got stabilizer(Clorox 100% CYA granules). Can this be placed in the same box, or should it be kept away from the muriatic acid?
    Thanks.
    In Ground Pool roughly 13,500 gallons, autofilled from home soft water.
    Pebble with glass/abalone mixed in, installed in 2014/Taylor TF-100 test kit
    Pentair FNS Plus 60 Filter/Intelliflo Variable Speed Pump/IntelliChlor IC40(Ideal salt 3400)
    Pentair MasterTemp 400 (Gas)/Automation Easy Touch(goes up to Aux 7)
    Mark R's Avatar
    Nov 2013
    Desert Southwest, USA
    166
    Re: Storage....
    Not an expert by any means, but, I'd keep everything away from MA. Stuff eats through metal even through the vent caps.
    12k gal Gunite/Hayward filter C5520BH with quad 33 inch filters. 2.5 hp motor. Pool is on south side, so full sun light. Spill over spa.
    Laar's heater LT250-Low NOx Gas Fired for pool/spa 250,000 BTU. Roof mount 6 panel solar system installed east/south. TF-100 test kit. May-September 100+ degrees out side.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: Storage....
    I don't THINK CYA matters cause it doesn't outgas like bleach and MA do.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Storage....
    I would not keep the MA in any container or enclosure that had equipment containing any metal components. The hydrochloric acid vapors can build up over time and lead to corrosion of metal parts. Don't store MA near bleach/liquid shock either.
    Isolated Spa - 345 Gallons
