Results 1 to 10 of 10
Thread: New pool owner
    Aug 2015
    Houston
    7
    New pool owner
    I posted in another part of the forum but looks like here is where to go. New pool just opened this week we have been able to use it since Tuesday. No issues yet but been doing a ton of reading and I am getting to where I want to add Borates to the pool Read the faq on it but not sure if I should even try it before the pool has time to settle in and the number to settle out. I have been testing with the cheap strips that the builder gave me but planning to get a TFT 100 hopefully next week.
    IG pebbletec 21k gallon with cartridge filter Jandy VSP 2hp pump and a 15' 12" wall with 3 scuppers. one skimmer, one floor drain all independently piped with 2.5 in lines.
    Jun 2014
    15,298
    Re: New pool owner
    TF-100! Music to our ears.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: New pool owner
    Wow...all 2.5" lines? Thems is some biggish pipes! So you are day 2 or 3 since the initial fill-up of your water?
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: New pool owner
    If this is a *brand new* pool with pebbletec finish I would wait to add borates until you know all the cement has cured, which may take months.
    Your new pool will cause your pH to require monitoring and acid administration and borates can make that more difficult to manage.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: New pool owner
    Yes, YS is correct: you might use as much acid as chlorine while the plaster cures! I'm on day 35 of a brand new Pebble Sheen refinish of the pool and my pH is slowing down in terms of racing to 8.0+ but I still need to add acid about 2x/week now.
    ----Chris----
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    Re: New pool owner
    TFP recommends you wait on adding the borates until you have a couple months under your belt on testing, and keep your water balanced. Get a grip on the basics first and understand the effects of adding stuff before you start adding borates.
    Divin Dave,
    Aug 2015
    Houston
    7
    Re: New pool owner
    Well I tested and came up with
    FC 4
    CC .2
    PH 7.7
    TA 43
    and Borates are showing at 28. I did not add them the builder did as part of the startup. I plan to not add any more till I get everything settled and the plaster has at least a couple of months to cure maybe even wait till I open in the summer which for Houston wont be that long.
    Jun 2014
    15,298
    Re: New pool owner
    Is this with your TF-100? What about your CYA level? That's really critical.
    Aug 2015
    Houston
    7
    Re: New pool owner
    Sorry got dragged into my finals for the semester by CYA is 48.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: New pool owner
    Hard to see that kind of resolution with CYA...I'd call it 50.
    ----Chris----
