Results 1 to 10 of 10
Thread: Adding cya sock method.
    Jun 2015
    Mesa, AZ
    16
    When I read toss the sock into the skimmer. Is this the skimmer attached to pump? Do I need to worry about flow restrictions, I'm starting from a 0 CYA... Or do multiple doses with needing so much?
    22' X 52" Intex Ultra Frame AGP 10,400 gallons
    Intex 3,000 GPH sand filter & Hayward thru-wall skimmer
    Taylor K-2006 test kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Adding cya sock method.
    Intex pools many times do not have skimmers. They only have a return port that pushes water into the pool and a suction port that pulls water out of the pool. In this case where you don't have a skimmer like this:
    Then you want to hang the sock in front of the return opening where water is going into the pool. Use a weight outside the pool and a rope/string to keep the sock at the proper height, in front of the return, not resting against the pool liner.
    Isolated Spa - 345 Gallons
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Wouldn't it be easier and faster to use liquid stabilizer?
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Quote Originally Posted by kywildcats View Post
    Yes, but much more costly.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    oops! ya beat me YS.
    Yes it would. Also, very costly.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2014
    15,221
    Liquid is easier and quicker, but at about 2-3 times the cost.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Ok, Thanks guys......I'm still trying to absorb everything!!!
    Mark
    Jun 2015
    Mesa, AZ
    16
    JVTrain: ooops i should add that to my sig. i do have a hayward thru-wall skimmer i installed also, thats why i was wondering which skimmer basket i keep reading about.
    I ended up going to leslie's pool and buying a gallong of liquid for $38
    Jan 2012
    7,367
    One gallon (128 oz) should have raised your CYA by aprox 36ppm.
    jv92red's Avatar
    Mar 2013
    SoCal
    117
    I had to raise my CYA up today as well. Not a big issue using the powder. I used a zip tie to close the top of the sock and another zip tie to attach it the the end of the hose shut off. Placed right in front of my strongest return. When the pool is off it hangs without touching the side of the pool. Here's a pic of my set up:
    15'x35' IG 16,500 gallons w/attached raised 18" spa continuous coping w/underneath spill and ledger stone wrapped, NPT mini pebble aqua blue w/2x pigment & abalone shell finish, 2"x24" travertine coping, 3x Jandy Color LED lights (2 in pool), Jandy Flo Pro 2HP VS pump, Jandy LXI (low NOx) 400K BTU heater, Jandy CL460 cartridge filter, Jandy AquaPure Ei SWG, Jandy Z4 automation with iAqualink and remote poolside PDA, 1,300 sqft Belgard Catalina paver deck with drainage, fire pit that matches the spa with travertine coping and wrapped in ledger stone, Elitewood insulated patio cover, Vinyl gates, back vinyl fence coming soon...
    TF-100
