Results 1 to 8 of 8
Thread: Disappearing chemicals?
    Jul 2012
    Saugerties, NY
    447
    Today I was told about a pool that one of my coworkers takes care of. Every week the pool is low on salt. The pool has an automatic filler, so we have been working under the assumption that it is probably losing water, and the autofill keeps it topped off. Today the pool was low on salt again. It had dropped by about 200 ppm since last week. When the tech tested the CYA, he found that the CYA had not dropped. So how could it be possible to lose 200 ppm salt, but not see a change in the CYA?
    TreeFiter
    Pool Technician
    Saugerties, NY
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,183
    Re: Disappearing chemicals?
    Is the pool using stabilized chlorine in some form that may be keeping the CYA up, but obviously not the salt? Is the pool,owner throwing tabs in the skimmer or shocking with dichlor that you guy is not adding?
    Support the site
    Jul 2012
    Saugerties, NY
    447
    Quote Originally Posted by tim5055 View Post
    Not likely. Its a relatively new pool, and has had a SWG from the start. Whenever there has been any issue in the past, this customer would call the tech for guidance. I really doubt she is adding anything to the pool without talking to him about it first.
    TreeFiter
    Pool Technician
    Saugerties, NY
    30,402
    200 ppm is within the error of the salt test. We don't know if it lost any or not.
    Jul 2012
    Saugerties, NY
    447
    Its low every week despite adding salt over and over again. Its usually around 2500-2600ppm. If it were the margin of error of the test being used, I would think that after adding salt week after week, the test would start to register well above this.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Mar 2007
    San Rafael, CA USA
    12,082
    How about the CH, is that dropping too? Of course, if the CH is low because it's not a plaster pool then a drop in CH can be hard to detect.
    30,402
    Regardless, you cannot take a 200 ppm loss from one week to the next and call that a loss. If at the end of four weeks, you are down 800 ppm then that is a loss that's actionable.
    If you replenish 200 ppm every week and it never rises, that's actionable, too. There is no answer for that however as you have ruled out replacemant water.
    Jul 2012
    Saugerties, NY
    447
    Quote Originally Posted by chem geek View Post
    I don't have any information regarding the CH, but I'm not sure I would put much confidence in it either way since the autofill is using well water. Whatever CH is in the pool may have come from the well in the first place. Might be worth looking at it, but I'm not sure I would put too much confidence in it.
    TreeFiter
    Pool Technician
    Saugerties, NY
