Results 1 to 9 of 9
Thread: Which Pump to get?
    Which Pump to get?
    My motor has died (1HP) and the pump is old and suspect as well. I am electing to replace the whole assembly. I am considering trying a multi speed or variable speed. Good idea? If so, which model should I consider? I've look at the Pentair Superflo for a single speed and the Intelliflow for a VS - just not sure which one I need.
    Thanks!
    BTW, contrary to what my signature says, I'm at about 18,000 gallons.
    1) 10,000 Gallons
    2) Cartridge Filter
    3) IG
    4) Pebble
    5) Hayward NorthStar Self Priming pump and a Hayward Swimclear Cartridge Filter
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Which Pump to get?
    What about a SuperFlo two speed?
    A VS is a good choice in areas where you have very expensive electricity or you need more than two flow rates. However in most of the country, a two speed will have a lower lifetime cost than a VS.
    Mark
    How do you control the speeds? Is that built onto the pump or would I be adding a switch somewhere?
    1) 10,000 Gallons
    2) Cartridge Filter
    3) IG
    4) Pebble
    mas985's Avatar
    Pleasanton, CA
    11,737
    You can have a manual switch, timer or a controller. It is up to you.
    However, you could just replace your current motor with a two speed and a built in timer like this:
    A.O. Smith 1 HP Full Rate Two Speed Motor W/ Timer - Round Flange (B975T,B2975T) - INYOPools.com
    Mark
    May 2015
    Quebec, QC
    37
    These pumps are all the rage here; they are water-cooled, so virtually silent and the heat is transferred to the pool Silensor Pool Pumps | Davey
    They are made in New Zealand, so not sure who distributes them in the U.S.
    14 x 28 Jacuzzi vinyl inground pool, Jacuzzi Laser 250 sand filter, Hayward 1 HP pump.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Eauclair - That is an interesting pump! But it is all 'metric' and wouldn't 'work' here in the US of A! LOL! I assume they can run on 60 Hz if you're using 'em up there in the Great White North.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    May 2015
    Quebec, QC
    37
    We share the same 1.5 or 2 inch pool plumbing fixtures. The pool industry here is non-metric. Costco Canada sells it online: http://www.costco.ca/Nirvana-Silenso...=10302&refine=
    Quebec has its own distributor, Nirvana pumps, so Costco can't sell that item in our province. It even looks like Nirvana is importing the pumps and using Costco.ca as a distribution channel for the rest of Canada.
    Aug 2015
    Maine
    45
    I purchased a variable speed Bluetorrent pump off eBay for $300 and it has already paid for itself in power savings. Skip the two speed, if you are pondering that route, and go variable.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I love my Pentair Intelliflo pump. But, it is a lot of pump. I never run it full speed not even for solar and waterfall. But, I will buy another one the day it breaks. They also make a smaller VS pump, 342001 superflo
    Pentair SuperFlo VS Pump 342001 | Pentair 342001
