Thread: DE Filter closing
    Jun 2015
    middlesex, nj
    4
    DE Filter closing
    Hi all,
    First summer has been a success, pool has been sparkling all summer. Starting to think ahead to closing, I am going to attempt to DYI and I am curious about what I should do filter wise. I have not backwashed all summer, pressure only moved 1 psi all summer, and the pool has been immaculate. Is there a need to open my filter up and clean it come closing time? Or should I just backwash before I close for the winter? Thanks in advance!
    16x32 pool approx. 26,000 gallons
    IG vinyl Hayward 4820 DE filter Hayward 1.5hp pump
    Built 1980's maybe...New liner 6/5/15
    Leslies test strips/ City water
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: DE Filter closing
    I would back wash thoroughly and remove the grids from the filter and clean them very well. Then either store them inside or reinstall them in the filter for the winter. Be sure to leave the drain valve open on the filter over the winter.
    Isolated Spa - 345 Gallons
    Jun 2015
    middlesex, nj
    4
    Many thanks!
